Hi can anyone please help ?
I have a camcorder that records in MPEG-4 format I want to burn this to a DVD-RAM and play it on my Blueray player which only plays AVCHD, Im not fussed about the quality too much.
Thanks for reading any advise would be great.![]()
Load the mp4 into multiavchd and author to avchd and welcome to the forums.
what kind of mpeg-4 ? there are several kinds. use mediainfo
if it's not AVCHD compatible h.264 , then it has to be re-encoded to be compliant (quality loss , slower).
if you have to re-encode it, you could try avchdcoder
if it is compatible , then you can just mux it with tsmuxer (no quality loss, very fast) -
it is HD MPEG-4 AVC/H.264 video - I have a Panasonic DMP-BD80 bluray I just want to put the video onto a DVD-RAM so I can play it on the BLURAY player - not too fussed about the quality etc.
Thank you for your time -
Then it sounds like you should be able use Tsmuxer or multiavchd as suggested. Click on them for guides.
If they are too complicated you can use trialwares like tmpgenc authoring works to output an avchd/blu-ray.
How do I convert MP4 to AVCHD?
By rnaval in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Nov 2015, 02:50 -
how can i down convert avchd
By jamminj2b in forum Newbie / General discussionsReplies: 7Last Post: 1st Jan 2012, 18:19 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Convert AVCHD
By mkrve in forum Video ConversionReplies: 36Last Post: 7th May 2010, 02:39 -
Convert AVCHD to AVI?
By i_c_e in forum Video ConversionReplies: 3Last Post: 12th Feb 2009, 04:23
