Hello,
I was going to make a disc of divx videos for a friend who has the Philips DVP3962 player. I know the player supports divx, but could someone who has this model confirm whether it can handle subfolders? I.e. the disc has the videos in different folders and you can browse them like menus? Thanks!
I don't have this model, but I can tell you that I have owned and worked with various Philips models and ALL of them can do what you propose. Do note, however, that while browsing the disc is no problem, there are always limitations on what DVD players will play in terms of Divx. High def Divx is out, for example. Here's a stick that talks about what encoding options don't work on some DVD players.
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video -
I don't have this model, but I can tell you that I have owned and worked with other Philips models.
You cant browse them like menus .. they will look like any file selection box on a win machine, not dvd menusLast edited by RabidDog; 29th Jan 2010 at 18:29. Reason: eco-waste recycling
@jman98: Many thanks for the response and the helpful link.
@RabidDog: Thank you! -
Also, make sure you don't put too many folders on the disc and files in those folders. The DVP3962 probably has a limit on how many folders and files can be on a disc, so keep both low, just to be safe.
(I know my DVP-5990 does (see here for TechFlaws' FAQ on the 3260 and 5990 - it mentions the limits, and those probably apply to the 3962, as well. Not sure about my old DVP-642...))If cameras add ten pounds, why would people want to eat them?
How to create playable Blu-Ray disc from BR-folders?
By Hotterjoe in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 11:11 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 14:48 -
Issues in traversing folders in Philips DVP 5990 ! Please help!
By neo76 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Aug 2009, 14:52 -
Question on DVP3962
By 24inchdubz in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Aug 2009, 13:42 -
Philips DVP5982 - USB hard drive folders not all showing
By PunkHippie in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Sep 2007, 13:58
