I am using rip-it to rip dvds for personal use in our car for the kids. I am having a hard time with some. It seems that if the actual dvd is larger than 4.7 GB it cannot be copied on a regular dvd. Anyone has any suggestions, any idea if you compress the dvd can you burn it? Any help would be greatly appreciated
thank you
Results 1 to 11 of 11
Rip it? Do you mean RipIt4Me? Not updated anymore, for years now in fact. Which is not to say it won't rip the vast majority of DVDs you may buy. But anything with newish copy protection is likely to defeat it.
The only free DVD decrypters/rippers regularly updated are DVDFabHDDecrypter, and (infrequently) DVD43. Payware options are DVDFab and AnyDVD.
You can easily "compress" a disc to DVD5 size with a transcoder like DVDShrink. Or use DVDRebuilder for better quality. Burn with ImgBurn only.
Good luck and welcome to the forum.
Pull! Bang! Darn! -
Thank you all for the replies, I think I may not have been clear enough so here is some more details. I am using mac os X. I have rip it installed on my lap top. I have no issues with the program ripping a dvd, the issue is that when the program reads and copies the movie to my HD, when I try to burn it afterwards on a blank dvd, if it is more than 4.7GB I cannot. I am asking if there is a way to compress it at that time before burning it.
Thank you in advance for your suggestions. -
ok your using Mac OS X.....
Those i listed are for Windows ONly....
then, its not free, but you can use DVDRemaster
this will compress and burn your Movie to a standard 4.7GB Blank DVD Disc
http://www.metakine.com/products/dvdremaster/ -
thank you eskro!
is this a totally new program or is it mainly for compressing my movies?
if I purchase it, will I need to use both programs? -
The following describes how DVDRemaster can be used to copy a DVD and preserve all the original content.
We will cover the following topics:
- Requirements
Prerequisites to successfully complete this tutorial. - Reading a DVD
Importing a DVD on your hard disk or using it directly from your DVD drive. - Setting up DVDRemaster
Explaining some of the DVDRemaster settings relevant for this tutorial. - Remastering, burning and after
Describing what happens during and after the recompression.
- Requirements
DVDRemaster // DVD2oneX2
They both can do the samething.... and cost the same :P
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 09:30 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
