I've been working on getting my motion clips to display properly from my .mpg files and can't get them to work no matter what I try.
I posted this
https://forum.videohelp.com/threads/315795-Motion-Clips-in-DVD-menu-do-not-display-prop...27#post1954227
but I don't think its AVISynth causing the problem. I've resized the video in my .avs script from the defult 100,66 all the way up to 720, 480 and it still display with horrible lines. I attached a screen shots. 1 is the normal settings, 2 is chaning the script to 720,480 so its the exact same size as my .mpg files. The mpg's play fine on their own, they play fine after I rip the .ISO, I just can't get the motion clips to play right at all.
My video is .mpg, 720x480 interlaced and as I stated, it plays fine before and after I author the dvd.
I tired deinterlacing the mpg in my .avs script but that didn't seem to make any difference other than the lines with a serious flicker added to it.
any help would be great!
thanks
Results 1 to 1 of 1
DVD menu does not display properly - items missing - please help
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 10th Aug 2011, 04:51 -
Motion Clips in DVD menu do not display properly.
By Phototechman in forum Authoring (DVD)Replies: 20Last Post: 2nd Feb 2010, 15:38 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 13:12 -
Can't get .mkv subtitles to display/work properly
By ChronoSquare in forum SubtitleReplies: 3Last Post: 26th Dec 2007, 15:36 -
How to get thunderbird to display emails properly?
By Rudyard in forum ComputerReplies: 0Last Post: 10th Jul 2007, 20:31
