  1. hello, I'm new to this so here goes, I'm trying to convert vob files to play on my ipod, vob files are perfectly in sync before I try to convert. I have tried WINFF and ANY VIDEO CONVERTER, cant seem to get the output in sync, I have tried alot of things in the options but still cant figure it out, while searching the net, I see this is a common problem, any help would be appreciated, thx
    Try instead handbrake, choose to open a dvd and choose the folder with the vob,ifo and bup files. Select the ipod profile and convert.
    Or do you just have the vob files? Cause just converting vob files can cause audio sync problems. You should always try convert from a complete dvd.
  3. thx, I will try that, and let you know what happens
  4. success, handbrake worked great, thx alot baldrick!!!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    I guess you mean staxrip?
    edit: Ooops. Wrong thread. Ignore this. .
