I set the capture to go of and set it to S-video and when the timer goes off it capture's who Cable. Is there any way to fix this
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
I have successfully used a scheduler called Wincron to start my S-Video captures. I leave the TV app on, and use Wincron to send a CTRL-R to turn it on, and again to turn it off at the desired time. I also discovered that my cable box can be set to change channels for specific shows, so I can capture 2 or more events without being there.
First Timer..CPU Build Help.
By Texxas_Boy in forum ComputerReplies: 23Last Post: 20th Feb 2012, 21:20 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 16:54 -
Capture to MPG on timer
By bolintx in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2008, 18:20 -
Timer controlled DVD player?
By that Todd guy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Aug 2007, 13:16 -
Help with Timer in Sony Vegas 6.0
By petersju in forum EditingReplies: 1Last Post: 11th Jun 2007, 20:54
