I was wondering, since it's inconvinient to continually Demux the avi footage from files encoded to mkv with x264 in Staxrip, is it possible to use AviSynth and virtuadubmod to manually encode videos with the updated X264 cli and save to an avi? If so, is there a guide on the avisynth wiki explaining all the commands to manipulate the speed (i.e. placebo, very slow etc.) and quality (baseline, high) for x264?
You don't have to demux anything. Just make your own scripts and use a front end that doesn't demux (e.g megui, or lord mulder's simple GUI) or even the CLI to encode. It's much faster if you do this, it doesn't waste time analyzing or demuxing etc...
New versions of x264 don't even need avisynth scripts (you may still need some avisynth plugins) , they can encode directly from the source without any other programs
Dig through the history in the mediawiki for the preset explanations (they had been removed)
http://mewiki.project357.com/index.php?title=X264_Settings&oldid=3821
You can't use vdubmod with x264 CLI without frameserving. You don't want to use AVI container with x264 , because of possible incompatibilites with b-frames, playback issues. x264 doesn't support AVI officially anyway, it only has support for .mp4, .mkv, .flv natively without other programs -
I'm not sure what you're asking?then how do you use x264.exe to do so.
You type the commands in
You need a version that has been compiled with LAVF/FFMS
http://forum.doom9.org/showthread.php?t=151733
Problem with x264.exe (MeGui)
By yomz in forum Video ConversionReplies: 7Last Post: 28th Sep 2011, 22:23 -
x264.exe error in mequi
By Banaanas in forum Video ConversionReplies: 6Last Post: 31st Jan 2010, 15:41 -
Where Do I Put The x264.EXE?
By hech54 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2009, 15:23 -
x264.exe has stopped working
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 17:42 -
x264.exe error
By streetak in forum Blu-ray RippingReplies: 1Last Post: 1st Feb 2009, 13:17
