Hey,
Noob problem I'm guessing.
I want to author a DVD with some .mkv files using Adobe Encore.
However, that program obviously doesn't support the .mkv container format.
So, seeing as frameserving has been a pain, I'm looking to convert the .mkvs
How should I best go about this so as not to waste video quality?
To clarify, which format would I be best to convert them to so Encore
doesn't have to reconvert them, once they have been imported, to author the DVD.
I assume multiple conversions to the wrong formats (lossy ones) will effect the quality?
And what program should I make these conversions with (free is preferable)
I apologise for any technical mistakes I made, and my lack of understanding.
Thanks.
AVStoDVD. You can choose to output elementary audio and video streams instead of an authored DVD. These can be brought into Encore (or any other authoring tool) to add menus etc. This is far preferable to pointless conversions to AVI, then to DVD. If Encore does try to reconvert output from AVStoDVD, ditch it and get something that is DVD compliant.
AVStoDVD is free, reasonably configurable, uses the high quality HCEnc encoder, and is well supported here by it's author.Read my blog here.
MVK > DVD via ConvertXToDVD ... I wouldn't mess around with Encore. It's not the right tool here.
If you must, you can extract the MPEG from ConvertX, then use those to re-author in Encore.
But good luck with that. Encore is overly anal on input.Want my help? Ask here! (not via PM!)
MKV to AVI without quality loss - for watching on DVD player
By mr-scarface in forum Video ConversionReplies: 19Last Post: 17th Apr 2013, 17:59 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 10:51 -
convert mkv to avi with the same quality. How ?
By SB4 in forum Video ConversionReplies: 10Last Post: 30th Jan 2009, 07:26
