Does anyone know if it's possible to repackage a matroska file to .divx with subtitle stream and no reconding the same way that AVIAddXSubs does for avi files?
BTW does it need user input for idx/sub support? Does it turn them to subrit format or does the .divx container allow for vobsub format support?
Results 1 to 10 of 10
Only if your mkv contains mpeg4-asp (divx or xvid) video. The .divx format doesn't support h.264 video, which is more commonly used with .mkv , and the divx ultra standalone players will not play h.264 video anyway
.divx container allows idx/sub format, and srt -
Isnt there an alternative container that allows for h264 and subtitles, since mkv is not widely supported on external hardware.
I can repackage mkv to vob (.mpg) but as far as i know .mpg cant allow for subtitle streams.
Any suggesftions? -
It's getting there, many media boxes like Tvix, popcorn hour, wdtv, patriot etc... support mkv and other formats. Some of the models are ~$100 USD
If you mean DivX dvd players, they don't support h264 at all, so what you're trying to do is useless anyway
HTPC can certainly play back nearly anything, so If you mean some other type of "external hardware", please clarify.
But to answer your question, transport streams (e.g. .m2ts) support h.264 video and subs. You could use tsmuxer for example. -
The Device i'm mostly interested in is the PS3 gaming console. As far as i know it supports tsmuxer created files, but i havent tried that yet.
Let me give it a shot. I hope it doesnt transcode anything.
EDIT i just tried tsmuxer and used an .m2ts output. File was playable but subtitles and chapters were unavailable. I dont think i did something wrongg, but it is possible that the ps3 doesnt handle additional streams from .m2ts files.Last edited by therock003; 29th Jan 2010 at 12:01.
blu-ray uses the same format , and ps3 can play subs fine
you might try multiavchd instead, it uses a slightly different muxer -
Nope, still no subtitle support and i dont know why. I keep hearing that the ps doesnt want to display subtitles with hd mateerial.
I even tried the suggestion to save the srt file with utf-8 encoding and select ps3 as my output on multiavchd but still it doesnt list any available subtitle stream upon ps3 playback.
That's a bummer.... -
Just to be safe (not that I'm sure it'd really help), is the PS3's firmware completely up-to-date?
If cameras add ten pounds, why would people want to eat them? -
I dont have the latest but there no reports to base that this is the issue. AFAIK no fw version seem to support avchd subs.
BTW as for divx xsubs, is there a way to make them more likeable? They are very sharp and have edges all around and look bad on my 50' screen. -
You can't have subtitles and chapters when you play directly the .m2ts file (or when you stream it). You need to copy/use the whole AVCHD structure. Then you can have menus, DTS audio, VC-1 video, chapters, subtitles, TrueHD audio and a lot more.
DeanLaugh and the world will laugh with you. Cry and you will be alone
aviaddxsubs problem need help
By higina in forum SubtitleReplies: 9Last Post: 14th Aug 2021, 12:28 -
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 19:55 -
any inside info o whether or not xbox360 will support matroska in upcoming
By craig198 in forum Video ConversionReplies: 41Last Post: 31st Aug 2008, 23:34 -
Features not listed: udf, multisession, ogg/vorbis and matroska support
By Lucas Malor in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st Jul 2008, 09:17 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01
