This may be something simple, but I recently purchased Cineform NEOScene to convert the native files from my Canon 7D into the correct aspect ratio and so the files would be able to be edited without stalling in Adobe PRemiere CS4. When I had downloaded the trial version of NeoScene everything worked perfectly. When I purchased the actual version, everytime I convert a clip and move it into Premiere a solid green screen flashes throughout the clip. Could this may be something simple, like a setting in Premiere or NeoScene, or is this an issue other people are having with the full version of NeoScene. I would appreciate any help I could get.
Did you upgrade to the latest version?
http://estore.cineform.com/downloads.aspx
July 10: v1.34 Build 119
Added: 64-bit Video for Windows codec for 64-bit applications.
Enhanced: CS4 decoder performance.
Fixed: CS4 frame duplication/skip
Fixed: CS4 decoder green flashes.
Fixed: Some 720p files in CS4 came in as interlaced."Quality is cool, but don't forget... Content is King!" -
I updated the 1.50 version, but maybe I should try the one you pointed out. Thanks for pointing this out to me!
I can't find a link to an older update, but I think that would be strange to go to an earlier update, but the latest update didn't fix the problem. Any other suggestions?
You can file a support ticket with cineform ; unlike other companies, they respond usually within a day or so (or so I've heard)
Yeah, I've actually sent them a message already; still haven't heard back. It's been about 2 days. Thanks for the reply.
Cineform Neoscene and Prem Pro CS3.2 questions/Quest
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 33Last Post: 4th Sep 2011, 21:04 -
HD PVR and cineform neoscene
By Tahlos in forum Newbie / General discussionsReplies: 3Last Post: 19th Jun 2010, 22:11 -
AVCHD EDITING IN Adobe Premiere CS4
By Don Man in forum EditingReplies: 10Last Post: 4th Jun 2010, 15:41 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Adobe Premiere CS4 pdf Tutorials
By MI6 in forum EditingReplies: 1Last Post: 15th Dec 2008, 10:20
