How do I create a karaoke dvd from Iso files or when I have downloaded the audio and video files? How do you put the audio and video files together with my dvd burner? Do I still need a special program? I don't need to turn my songs into karaoke songs... I've already downloaded the songs as karaoke songs. So confused...
usually, Karaoke files comes in 2 parts like this
.CDG --> contains the Lyrics
.MP3 --> contains the Music
now theres some applications
that can convert these 2 into 1 video file!
To name a few:
- Power CD+G to Video Karaoke Converter
- Karaoke Builder Studio
- KaraFun Studio
Now once converted to a video format,
u can just use any DVD Authoring software to finish the job....
by that i mean convert your video to DVD of course...
to name a few:
- AVS2DVD
- DVD Flick
- ConvertXtoDVD
- Nero Vision
Hope this helps!Last edited by eskro; 28th Jan 2010 at 22:52.
I downloaded two different Karaoke folders...
The first folder has 2 subfolders... one with mp3 files and the other with video clips. When I opened one of the video clip files it opened in windows media player and had both audio and video. Does this mean if I burn only the video clip files to dvd .... ta da... I will have a Karaoke Dvd?
The second folder has only iso files.... I've never used iso files before.... so you're saying if I use imgburn to burn them on to dvd it should work?
Sorry about the cross post....
Thanks for the help... -
try to move your video clips like lets say on your desktop......
just your video clips,,,,, not your MP3 files....
then try to run a video clip to see if u have sound....
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
Karaoke DVD of China DVD Karaoke player
By d0ming in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Apr 2010, 07:17 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 15:53 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Ld karaoke to dvd karaoke
By volam in forum Video ConversionReplies: 0Last Post: 27th Mar 2008, 09:13
