The discussions here are detailed and I am at place where I could use that type of help. I have a Samsung Camcorder SC-MX20R that records on mp4 format. I am recording an hour long event with external audio. When i pull the two files on my computer Dell Dimension E520. I can play the two files no problem with VLC However, audio and video are out of sync using Avidemux. I want to put my program on DVD. First I join the two files using Avidemux. next I pull sound from an external source after I fix the audio and video sync problems I need to add an intro and outro (already created) and burn to dvd. I have tried avidemux but to line up the talking but that only worked at the beginning. the deeper i get into the file the more off it is. Any other software I should try or tricks that will get me up and running would be awesome. thanks
Help putting jpeg on a dvd!!
By ksorvick in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 14:02 -
putting vobs to dvds
By chuchi327 in forum Authoring (DVD)Replies: 4Last Post: 23rd Oct 2009, 19:38 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 12:56 -
Putting 2 videos together?
By phate53 in forum ComputerReplies: 3Last Post: 3rd Jun 2007, 21:21 -
Putting two DVD's into one
By Victor Hen in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 11:09
