I am trying to understand what the Quant value reported by HCenc is telling me about the quality of the encoding that I am doing. I am messing around with some of the various matrix files in HCenc to see what the result is on the final MPEG2 encode. I am taking a 2min video clip that is ~98% FILM. I am simply sending the clip through TITVC and encoding at 4000kbps with different matrices. I then compare that video to the original source to calculate SSIM (avisynth).
Here is what I see:
Visually, I have a pretty hard time telling them apart. AVAMAT7 looks softer than the others, but that's about what I can see (apparently I am not a very picky viewer visually!Code:Matrix Bitrate Quant SSIM MPEG 4000 6.714 75.51 MPEG STD 4000 6.93 74.54 FOX1 4000 12.528 74.71 MANONO1 4000 8.369 74.98 AVAMAT7 4000 4.615 74.14)
At any rate, the SSIM values are all fairly close but the reported Quant values from HCenc are vastly different. What exactly are they supposed to be telling me? Are Quant values reported from HCenc something that you can use to compare to some other type of encoder (like XVID)? I guess the values are much higher than I would expect for what I feel looks very comparable to the source, quality-wise.
				Results 1 to 9 of 9
	The final compression is the product of the Quant value and the matrix values, so if you set a fixed bitrate it is to be expected that the Quant values are higher using FOX1 than AVAMAT7.
 IMO the MPEG STD is bad because for non-intra (P and B-frames) the values for low and high frequencies are the same (all 16) meaning a lot of noise isn't quantized to zero.
 In my tests AVAMAT7 also is always low on SSIM, the MPEG matrix normally is pretty good on SSIM, in general HCLOW produces the highest SSIM metric values, but it doesn't mean it will give the best visual results.
 You can't compare MPEG2 Quant values to XVID (MPEG4) Quant values.HCenc at: http://hank315.nl
	So basically, I shouldn't worry about the Quant value that is reported after an encode, but rather find some combination that looks good to me? I thought maybe I was missing something that should have been obvious. FOX1 being ~12 vs ~6-8 for the others seemed to me that I should have been able to see something. I guess that FOX1 must keep more detail in the ranges that are not so visibly obvious to the human eye? Are those details also the ones that are thrown out first if I don't allow it enough bitrate?
 I had read this post that you made at the end of last year. I guess I had expected FOX1 to require ~2X the bitrate compared to MPEG matrix based off of that, so I wasn't surprised to see the high Quant. I didn't expect the quality to be basically the same (or the SSIM). That is what has me so confused.
	You definitely should worry about the quant value. You want to choose a matrix that gives you the quant value for the quality you want. For your particular source and bitrate, the Fox1 matrix is too 'good'. It winds up with too high a Q for the bitrate used. Granted, though, I have seen retail DVDs using that matrix with Q values (as measured by the free version of the Tecoltd Bitrate Viewer) nearly that high, I generally choose a matrix to give me an average quant (as measured by Bitrateviewer) of 7 or so, maybe a bit less when using lower quality matrices.
 Granted, the differences are minute, but I think if you saved out pics of the same frame from the different encodes, and then made a slide show out of them, you'd see differences. Me, though, I just rely on the Q values, mostly.
	Thanks, Manono. Nearly all of my re-encodes are just to embed subtitles into DVD rips (and maybe sharpen/denoise a bit) so that I can serve them up to my Tivo for playback. It sounds like you might actually do a bit of analysis up front and choose a matrix to hit your Quant target. Is that right?
 If I were to decide that I want to always use MPEG or MANONO1 as my default matrix, could I just encode at a constant Quant?  Would that result in a similar encode quality as finding out the required bitrate for the average Quant value and doing a 2-pass average bitrate encoding with HCenc? as my default matrix, could I just encode at a constant Quant?  Would that result in a similar encode quality as finding out the required bitrate for the average Quant value and doing a 2-pass average bitrate encoding with HCenc?
	Ok, thanks for the information.
 All right, I tried to answer my own question here. I had to use HCenc 0.23 instead of 0.24 since 1pass doesn't work for 0.24. I ran with MPEG matrix because MANONO1 doesn't exist in 0.23.
 MPEG, 4k 2-pass - TITVC, Undot.FluxsmoothT(3).LSFMod() - 5.617 Q, 3994 avg bitrate, 74.38 SSIM
 MPEG, 5.617 CQ - TITVC, Undot.FluxsmoothT(3).LSFMod() - 3898 avg bitrate, 72.92 SSIM
 MPEG, 5.5 CQ - TITVC, Undot.FluxsmoothT(3).LSFMod() - 4014 avg bitrate, 73.26 SSIM
 Comparable results, but not the same. Visually, they all look fine to me. I needed to drop Quant down a bit to match average bitrate. Final SSIM is lower with constant Q than with 2-pass bitrate.
	I agree with manono, it's better to have a quant value within a reasonable range, lets say 3 - 8, if it isn't in this range, I will choose a different matrix.
 A lot of things like bit rate control just work better when the quant value is within this range.
 If you want to use the manono1 matrix in HC023, just paste this in the ini file:
 *CUSTOMMATRIX
 8 8 8 9 11 13 14 17
 8 8 9 11 13 13 14 17
 8 8 11 12 13 14 17 94
 9 11 13 13 14 17 17 94
 11 11 13 13 14 17 94 94
 13 13 14 16 17 20 94 94
 13 13 14 17 94 94 94 94
 13 14 17 94 94 94 94 94
 12 12 13 14 15 16 22 26
 12 13 14 15 16 22 26 32
 13 14 15 16 22 26 32 41
 14 15 16 22 26 32 41 53
 15 16 22 26 32 41 53 94
 16 22 26 32 41 53 70 94
 22 26 32 41 53 70 94 94
 26 32 41 53 94 94 94 94HCenc at: http://hank315.nl
	Thanks a lot, Hank! I had just figured out the custom matrix myself and copied over the matrix parameters from 0.24. I am enjoying tinkering around with the settings in HCenc. Excellent program! With a little denoising and sharpening, I am able to get very good video even at 3000 kbps.
  HCenc and PanScanBy Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 18:35
  Problem with HCenc 0.24.By HolyFries in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 19:03
  HCenc QuestionBy Maikeru-sama in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 13:01
  HCEnc vs MVBRBy awesomer in forum Video ConversionReplies: 7Last Post: 31st Jul 2008, 19:12
  HCEncBy Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 10:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
