I am converting a load of PAL SHVS tapes (and some VHS).
Setup is Panasonic NV-HS800 >Svideo (& L&R Stereo) > ADVC300 > IEEE 1394 to PC
I bought ADVC300 as read that this would help with getting best I can from Analogue signal.
Should I look at also getting a TBC ? ........... or also read that using FFFT3DFilter with AVISynth is a benefit ...
Are there are sources for used TBC units .. only ones on Fleabay are new ones in US.
Advice welcome.
In case it makes any diffrence .. once in PC, I'm using Sony Vegas for editing then creating DVD at max bit rate MEG2
Read the 3rd post here: http://www.digitalfaq.com/forum/showthread.php/alternative-avt-8710-1853.html
That covers TBCs in depth. What to use, why and when.
About the ADVC-300, read these:
http://forum.doom9.org/showthread.php?t=152304 (start with post #7 in that thread, a few below it)
http://www.digitalfaq.com/forum/showthread.php/b-h-recommends-1847.html
https://forum.videohelp.com/threads/313473-NOTE-A-Canopus-DV-box-does-not-replace-a-TBC!
NOTE: Comments about 100 model also apply to 300 model.
You may not want a used TBC, as many of them are inferior.
Your best bet is with a AVT-8710 from B&H at http://www.bhphotovideo.com/c/product/276891-REG/AV_Toolbox_AVT_8710_AVT_8710_Multi_St...3167/KBID/4166
(B&H ships worldwide, they're an international company based in New York.)
AVISynth is useful post-capture, sure. Really depend son the errors you have.
VirtualDub is another option, with its many filters.Want my help? Ask here! (not via PM!)
Thanks for detailed reply ... seems 3 out of 4 for the ADVC300 ... but best used with a TBC.
Looks like I can get the TBC in UK ON, seems it is badged by many sellers.
I can get it locally as http://www.howtoconvert.co.uk/howtbc.htm
or http://www.avtoolbox.co.uk/tbcpage.shtml
etc.
Guess I need to buy
I assume I would you cable this between VCR and ADVC300
Be using SVideo ... is there any appreciable delay ? ... assume audio does not go through, in which case as there is extra processing on video signal is there a issue of synchronisation being lost. -
VCR > TBC > capture device --- yes, correct
No sync loss, no. If anything, it's negligible, a micro-portion of a second. (1/50th of a second)Want my help? Ask here! (not via PM!)
OK ... after your advice I did a bit of googling around and the AVT-8710 seems well respected for it's price.
So took the plunge and ordered one ....
Can you offer any tips of using one of these, do you just use it in 'plug & play' mode, if not welcome advice on what/how to set it up. -
Several threads at http://www.digitalfaq.com/forum/forumdisplay.php/restore-filter-improve-17.html
discuss timebase correctors and the AVT-8710 TBC in detail.Want my help? Ask here! (not via PM!)
I tried a search on that site .. but can't seem to find any details on how to set up / adjust the 8710 , can you advise or point me to any links.
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 09:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
