First time poster, but I've been reading the site for a while. Tons of great info. I have a bit of a newb question, but only because this is the first VCR I've owned with so many outputs.
What is the recommended method for hooking up the 1980 to a capture device, the BNC or SVID connector? Also, since there are two other outputs, can I connect one of them to my TV so I can monitor the feed? Finally, where if anything, do the coax connectors come into play?
My main concern is the loss of quality by possibly splitting the signal to both the TV and capture card, or it that even an issue with these models?
Use s-video
This same topic has been discussed a lot in recent months at
http://www.digitalfaq.com/forum/forumdisplay.php/capture-record-transfer-7.html
and http://www.digitalfaq.com/forum/forumdisplay.php/restore-filter-improve-17.html
If you want two displays, sure, BNC>composite adapter, composite to TV. No loss.Want my help? Ask here! (not via PM!)
I didn't even know there was such a site. Fantastic! Thank you for both the helpful reply and the faq links.
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
Reccomendation for the Panasonic AG-1980?
By sunsetandgower in forum RestorationReplies: 19Last Post: 3rd May 2010, 16:12 -
I have my Panasonic AG-1980...now what
By kissvid in forum RestorationReplies: 3Last Post: 1st Sep 2009, 07:34 -
Problems with Panasonic AG-1980
By henryperu77 in forum RestorationReplies: 1Last Post: 10th Jun 2009, 12:54 -
Calling other Panasonic NV-FS200 / AG-1980 users
By JoseD in forum RestorationReplies: 4Last Post: 27th Dec 2007, 17:17
