hello
i'm getting alittle confused here on making a vcd from an avi format. do i need to use a divx program to use tmpgenc? if so how do i use divx with tmpgenc ? i've tried to d/l divx 412 and 311 but couldn't figure out how to use it besides from seeing it in my program file .
one more thing please , i have tmpgenc , nero and vcdeasy,and vdub , do i need anything else to make a vcd, svcd etc no dvd's?
If you're converting divx to VCD MPEG, you need to have the divx codec installed. It allows TMPGENC and others to read the divx encoded file. You seem to have all the software you need for making VCDs.
/\/\ars /\/\ayhem -
thanks mars
my files are all avi's which i belive are divx, i think ? i d/l them from morpheus . how i would i be able to tell if i needed the divx codex , would the movie play after i encoded it with tmpgenc if i didn't have divx codex?
sorry for these seeming stupid questions -
The problem is, you may not be able to encode anything in TMPGEnc without having divx codecs installed first, as TMPGEnc uses the codec to decode the AVI (codec means COde/DECode). Think of a codec as a driver that lets the system understand how to view the file.
If you've encoded to VCD (MPEG1) then Windows Media Player should be able to handle it just fine.
If you've encoded to SVCD (MPEG2), you may need to install some DVD playback software to get Windows Media Player to read MPEG2 files (sometimes these files have an extension of .m2v), or download an MPEG2 codec that will make MPEG2's recognisable on your system.
Even if you have divx installed, you might have problems with TMPGEnc and VFAPI. Do a search on TMPGENC and VFAPI, look for articles that discuss "priority" of codecs. I had that problem where I could view divx in Media Player, but TMPGENC wouldn't read it.
No problem, we all have to start at the beginning. But I do suggest that you learn to search the Forum for past articles on the topic. This question gets asked probably once a week at least./\/\ars /\/\ayhem
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
