I have a damaged AVI file, I tried to fix it using several repair programs including VirtualDub but with no luck.
I opened the file with Hex editor, it is full of data, is there a way that I can extract AVI frames as images from this damaged file. I know the frams size, Thanks
VirtualDub's hex editor has a RIFF chunk tree view.
https://forum.videohelp.com/threads/315409-bad-video-dimensions-information?p=1953268&v...=1#post1953268
But this is a very far cry from being able to extract frames as images. Most frames in high compression codecs like Divx and Xvid do not stand alone. They only encode changes from frames before or after. Lower compression codecs like DV and HuffYUV encode each frame as a complete entity.Last edited by jagabo; 28th Jan 2010 at 07:53.
Extracting frames from VOB files
By omkar.parkhi in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2011, 16:25 -
Extracting subs/frames in 200 DPI
By user2008 in forum SubtitleReplies: 1Last Post: 9th Sep 2010, 10:39 -
Extracting Frames From Video Takes Forever
By FOBOS in forum ffmpegX general discussionReplies: 0Last Post: 14th Apr 2009, 11:20 -
Extracting jpg frames from Video files
By wrazoru in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2008, 05:08 -
FFMPEG: Extracting multiple frames at different intervals
By roden in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2007, 11:35
