I believe the first PCI Express cards arrived at the end of 2004 so a computer bought in 2005 might still have been AGP. I think you can tell which by going to Control Panel and selecting Display -> Settings tab -> Advanced button -> Adapter tab -> Properties button -> General tab. The Location field on my PCIe system says "PCI Slot 4". I don't have any AGP based computers around anymore but I think it would say AGP there.
Results 31 to 36 of 36
Open the PC and check which you have. Both are shown here.
http://dictionary.zdnet.com/definition/PCI+Express.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
havent looked in it yet but did go to display under location this is what it has though PCI bus 0, device 2, function 0
this is the card Mobile Intel(R) 4 Series Express Chipset Family -
that was under display adapters in the device mgr then went to its properties
This is the desktop?
If so, it seems like you are using a motherboard display chipset.
That doesn't help identify which type of display card expansion slot you have. You need to open the case and look or consult Dell documentation.Recommends: Kiva.org - Loans that change lives.
I had a guy suggest this site said he thought this would work....What you think????
www.svideo.com/vgactv.html
Can a Laptop with an Esata port Hook up to an Internal Bluray Writer?
By jbitakis in forum DVD & Blu-ray WritersReplies: 2Last Post: 10th Nov 2011, 21:16 -
need help, i want to hook my laptop to the tv
By sonicslayer in forum Newbie / General discussionsReplies: 15Last Post: 10th Jul 2011, 16:23 -
Looking to hook my laptop up to my 42 plasma
By marionr26 in forum Software PlayingReplies: 12Last Post: 26th Nov 2009, 17:35 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16 -
Laptop to TV using VGA and RCA?
By JediMoonShyne2 in forum Newbie / General discussionsReplies: 15Last Post: 9th Apr 2008, 16:51
