Results 1 to 30 of 36
    Aug 2009
    I have a VGA cable and I can run the vga from my pc to my lcd hd tv to the vga input on the back of the tv. It plays fine like that,but now Im trying to go a step further. I have a dvd recorder currently hooked up to that tv. Im trying to recorder with the dvd recorder what my laptop is displaying on my tv. See I have to use RGB input on tv to play pc thru tv. Well there is no way to recorder like that option not available on dvd recorder. Do I need a VGA to Component cable for this. thinking if I hook VGA to componet on back of my recorder and choose that source through the recorder it will let that source run so I can recorder whats playing on my laptop. Will this work??? Is that what I need like I say VGA cable from laptop to TV set source on tv to RGB that plays well just now need to play through recorder to rec but no VGA or RGB option on recorder........I appreciate all the feed back
    Aug 2009
    if you can post a link of what I need so I can see what it looks like I would be grateful
    Aug 2009
    maybe vga to component or vga to hdmi I dont have s-video on my laptop so thats out the question only on TV and dvd rec.
    Aug 2009
    i want to record a game off of espn360 for a keep sake I have my laptop and a dvd recorder with a built in hard drive how can I do this. I can run vga to my rgb input on back of tv it plays fine. I need to tie in the dvd recorder to record it Should I use VGA to componet maybe
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    VGA (RGBHV) doesn't connect to component (Y,Pb,Pr)
    http://www.kiva.org/about
    Aug 2009
    any ideas out there
  7. Member edDV's Avatar
    Mar 2004
    To record on your DVD recorder, you need to run the laptop in SD 720x480i mode and connect to the TV and recorder with the composite or S-Video out.
    Or, use a VGA to S-Video converter box like this
    http://www.google.com/products/catalog?hl=en&source=hp&q=VGA+to+S-video&oq=&um=1&ie=UT...wBg#ps-sellers
    or this
    http://www.amazon.com/notebook-S-Video-Converter-Adapter-Shipping/dp/B002PKNODS
    Don't expect great picture quality.
    Aug 2009
    i have hooked up VGA to VGA on back of tv and I thought the quality was pretty good,will this quality be as good as that????
  9. Member edDV's Avatar
    Mar 2004
    VGA should be good for HD resolutions. The best to use would match your LCD-TV panel resolution.
    S-Video or composite are SD 480i and downscaled.
    Aug 2009
    how about VGA to HDMI dont they make a cable that has VGA with a hdmi on the other end. That will be HD right?????
  11. Member edDV's Avatar
    Mar 2004
    Think about what you are saying.
    VGA is analog RGB with H and V sync.
    HDMI is digital clocked RGB or YCbCr.
    Explain to me how you connect those without a huge expensive hardware box in the middle?
    Aug 2009
    sorry when you said VGA should be good for HD in previous thats why I said HDMI thats HD too sorry
    Aug 2009
    easy to watch PC to tv hard to record though......
  14. Member edDV's Avatar
    Mar 2004
    Yes the VGA analog connection can be HD resolution. Best resolution should be that which matches your TV display (e.g. 1366x720).
    You can't easily record VGA.
    correction: 1366x768
  15. Your DVD recorder probably only has composite and s-video inputs. Those only carry standard definition video. Even if it has component or HDMI inputs that accept high definition signals it will downscale to standard definition before recording on the DVD.
    What you can do is get a high definition VGA to component video scan converter, then record that output with a Hauppauge HD PVR, and make AVCHD DVD or Blu-ray discs. You'll need a Blu-ray player to watch them of course.
    scan converter: http://www.vpi.us/vgacmp-tv.html
    Aug 2009
    how about if I add this to my Desktop PC http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829&nm_mc=OTC-17exta6&cm_m...ech-_-14102829
    And I have this HDTV monitor already hooked to it http://www.newegg.com/Product/Product.aspx?Item=N82E16824001280
    and this is the dvd recorder I want to hook to it http://reviews.cnet.com/video-players-and-recorders/magnavox-h2160mw9-dvd-recorder/450...-33452653.html
    So with this video card here can all this work and record off my PC if not in HD least with a good video quality
  17. Member edDV's Avatar
    Mar 2004
    You need a card that will do S-Video plus one of the following
    DVI-I (includes DVI-D and VGA)
    or
    HDMI
    Like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
  18. Member
    Aug 2009
    oh ok so I dont need HDMI on the card??? since my PC would have it,monitor has it and recorder has it.
  19. That DVD recorder does not have an HDMI input. So having an HDMI output on the graphics card won't help you record anything from the computer.
    This post:
    https://forum.videohelp.com/threads/283861-VGA-to-S-video?p=1756748&viewfull=1#post1756748
    has an approximation of what the desktop will look like via s-video.
  20. Member edDV's Avatar
    Mar 2004
    DVD recorders at most have RF, composite, S-Video and DV inputs. The DV input usually won't accept a computer connection, only a camcorder with device control enabled. So that leaves S-Video as the last best choice.
    Aug 2009
    so my dvd recorder does have hdmi so is that a output and not a input cause its hookup to hdmi now. Im not looking to use the S-Video for reading text just for movies and videos off the pc.....So will it be close to as clear as watch 480p on tv.
  22. So you're back to a VGA to s-video scan converter. That can look ok for standard definition video.
  23. Member
    Aug 2009
    the scan converter box will work for me without a new video card with S-video???? Or get the new card I dont need the scan converter?
    I know you guys be glad when this post ends..lol Think its coming to a end,but I thank each and everyone for there time. Saved me from buy stuff I dont need
  24. I thought you had a laptop -- which means you can't really get a new graphics card.
    A scan converter will take the analog VGA signal from your current laptop and convert it to NTSC television standard s-video or composite video. You should look for one that can handle your laptop's native resolution so you don't have to switch resolution all the time.
  25. Member edDV's Avatar
    Mar 2004
    I think he has two computers.
    A new video card in the desktop will be cheaper than a scan converter and will give a somewhat better picture.
    A scan converter would work with either computer.
  26. Member
    Aug 2009
    Yep a desktop and a laptop ok thanks a new video card with S-Video on the card and that will give a better picture. So the one card in previous post from newegg with the S-Video on it that will be fine for my Dell E510
    thanks guys !!!!!
  27. Member edDV's Avatar
    Mar 2004
    That card is for a PCI Express slot. Your Dell may be AGP. Check the specs.
  28. Yes, that card should work with your PC -- assuming you have a PCIe x16 slot. If your PC is very old it may have an AGP slot instead.
    It's probably not an issue for you but one other thing you should note: although the card has DVI, VGA, and component/s-video outputs you can probably only use two of them at once. So you can't have a DVI monitor, a VGA monitor, and a TV all hooked up and working at the same time.
  29. Member
    Aug 2009
    my desktop is from 2005 how can i tell if its PCI or AGP can I look like in my computer or device manager or do I open to look at it......actually Im just gonna hook up my dvd recorder to the pc when I want to record something it only be a monitor,pc,recorder when im done it will be unhooked. I was in Bestbuy today they only had like one video card with S-Video on it was sold out alot of them with hdmi. I never paid much attn to know that tv's didnt have outputs only inputs. Guess it dont need them. what are the DVI-D on the video cards good for? Nothing with what Im trying to do huh
    thanks again guys you been a big help Im about ready to get this card and see if it will let me do what I want to
