Hi there,
Is it possible to play asx files on my pc without needing access to the internet ?
Any help would be appreciated !
Kind Regards
	You can't.
 The asx file is a url link to the video asset on a remote server; i.e. it's not the actual video.
 You have to either download the actual video to your local computer, or screen capture it to your local computer to play offline
	The asx is usually just a pointer to an url for web streaming. So no.
 Instead try download the content from the asx using for example open it in VLC and use the record button. If it wont work you probably need something like wm recorder, tunebite, replay media catcher or wm capture.
	Host server can only tell if you are playing it; it cant differentiate if you are recording it too
  Continuing problem with "Offline Files" disconnectingBy Cornucopia in forum ComputerReplies: 5Last Post: 12th Apr 2012, 00:21
  FIles showing Offline?? But, I can see them?????????By bfleming76 in forum EditingReplies: 0Last Post: 6th Jan 2012, 11:36
  save a flash video and re-play it offline on MacBy lilly333 in forum Video Streaming DownloadingReplies: 6Last Post: 25th May 2008, 11:20
  Netflix offline?By JohnnyBob in forum Off topicReplies: 7Last Post: 27th Mar 2008, 13:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
