I have big files from WMV material.
But I need to cut them into smaller pieces.
Do you know any program that can do that for me? :P
PS: and joining WMV files? Are there any programs that can merge several pieces into 1 big file?
thanks
I use Windows Media File Editor to cut WMV files and ASFJoin to join ASF/WMV files.
You have to change the ASF extension to WMV to open with Windows Media File Editor. I like to open the file in Virtualdub first to find the times where I need to make my cuts. If you don't then it will try and cut at the nearest keyframe which could be nowhere near where you want to make your cuts (type in time under HH.MM.SS.MSEC and hit seek, this will find the exact place to cut file).
You need a copy of ASFbin.exe in the ASFJoin folder for ASFJoin to work. -
I could also find: ---> https://www.videohelp.com/forum/archive/solved-how-to-cut-wmv-without-re-encoding-t299037.html ---> https://www.videohelp.com/forum/archive/cutting-wmv-into-multiple-parts-t352965.html The tools: ---> http://www.radioactivepages.com/index.php?docid=asfbin§ion=software ( AsfBin ) ---> https://www.videohelp.com/tools/Cut_Assistant ( Cut Assistant) ---> https://www.videohelp.com/tools/Steeper ( Steeper ) Thanks. Best Regards. devil (johner)
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 11:26 -
[SOLVED] How to cut WMV without re-encoding?
By JestersTear in forum EditingReplies: 10Last Post: 6th Apr 2008, 04:10 -
How can i cut out a scene from a wmv?
By denadel in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 08:25 -
How do i author dvd menu with chapters + cut commericals...with a WMV??
By chocolate_brownie in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2007, 19:00
