Results 1 to 14 of 14
  1. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    hi there, i was rendering an .mov to .rm movie. Which have a 15 minutes of duration and 352x240 pixel. after i render fo 8 hour, it's not even 1 percent were rendered. So, what the problem or what did i do?
    Apr 2004
    Miskatonic U
    You probably need to supply a few more detail than that
    Read my blog here.
  3. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    source: .mov 352x240 16 bit sound, 8 bit video.
    Out: .rm 320x240 16 bit sound, 8 bit video
    duration : 15 minutes
    Render box said. 15 hours 18 minutes....Time remaining
    8 hour 5 minutes 42 second time elapsed
    The time still increasing but the render percent still zero.
    I don't activate any application and set high priority to vegas....
    Apr 2004
    Miskatonic U
    Never tried to output rm from Vegas. Try outputting to another format to see where the problem lies.
    Read my blog here.
  5. what are ur settings? there is a prob forsure
  6. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    allight, i'll try render to wmv... 350kbps......
    What option? I use default setting
  7. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    i tried to render to wmv. 512kpbs video. But still in same condition
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You have something fundamental wrong with your system. I would be looking at HDDs and other issues. Of the source video is the problem.
    Read my blog here.
  9. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    oh thanks, i must finish this movie in 5 day. this is my first movie for TV. so i don`t want to let down my friends.....
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I hope it's a very small screen, because at that resolution it is going to look pretty rough.
    When you start rendering, open the Task Manager and look at the CPU and memory usage
    Read my blog here.
  11. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    it`s more than 130.000
    i set the priority to high ( before rendering)
  12. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    CPU : 00 (not changing)
    Memory : 142760K
  13. I Love You! k4z0's Avatar
    Jul 2009
    Indonesia
    allight , i found the probs. and now i can render it now. TOO much slot for sound. i deleted some of em and can be rendered normally (also faster)
    Thanks for your time!
    don`t have a friend.....
  14. can you describe it a bit with more details? i have the same problem i rendered yesterday a video that worked fine but today i want to render exact the same video but it doesn't work. 0% and i only can close vegas with task manager
