Closed Thread
  1. Hi guys,
    I am having some problems playing certain mkv files (music videos) on my Tvix media player. The problem is that every few seconds (especially when the scene seems to be changing) the file pauses then continues playing again. It seems that what they have in common is the small file size of the mkv files.
    However, some small mkv files also work fine. For example, this one does not run smoothly:
    General
    Complete name : timbaland_ft_drake-say_something-dvdrip-x264-2009-famous
    Format : Matroska
    File size : 45.5 MiB
    Overall bit rate : 1 451 Kbps
    Encoded date :
    Video
    Width : 624 pixels
    Height : 352 pixels
    Display aspect ratio : 1.33
    Frame rate : 29.970 fps
    Audio
    Format : AAC
    Stream size : 160 kbps
    This one is larger but also does not run smoothly:
    General
    Complete name : kid_cudi_ft_ratatat-pursuit_of_happiness-convert-dvdrip-x264-2009-famous
    Format : Matroska
    File size : 60.5 MiB
    Overall bit rate : 1 787 Kbps
    Encoded date : 01-06-2010
    Video
    Width : 704 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Audio
    Format : AAC
    Stream size : 256 kbps
    However, this one works fine and the file is quite small:
    General
    Complete name : dirty_money-love_come_down-dvdrip-x264-famous
    Format : Matroska
    File size : 47.7 MiB
    Overall bit rate : 1 509 Kbps
    Encoded date : 12-30-2009
    Video
    Width : 720 pixels
    Height : 368 pixels
    Audio
    Format : AAC
    Bit rate : 160 kbps
    Does anyone know the issue or a program I can use to fix it? I thought maybe increasing the resolution might help?
    Please let me know if you have any ideas.
    Joe
    Just buy the movies instead of downloading dvdrips.
