I have a question under MODE for ISO for DVD Decrypter.
If I go to "read" does it extract whatever is in my drive onto my hard drive as an ISO?
If I go to "write" does it extract then burn it? Or does it find an ISO file from my computer to burn? (I always thought only programs like Nero allows to burn and DVD Decrypter only extracts)
If you are just doing ISO copies, I would suggest you use Imgburn instead. It is the (much) upgraded version of DVD Decrypter, minus the DVD decrypting bits.
That said, both of them work in the same way. Read puts an ISO on your HDD, Write takes an ISO from your HDD and burns it to disc. Neither have a single step create ISO, switch disc, burn ISO mode.Read my blog here.
guns1inger, thank you. Imgburn works the best.
A side question. I also tried using Nero Burning ROM. I selected DVD-ISO to burn my ISO file. But it says that the ISO file is bigger than 2GB, so I need to select DVD-UDF. Does that still burn it as an ISO or does it burn it as a data file? I need to burn an ISO file, not as a data....not sure if DVD-UDF make a difference.
Does anyone know why Nero has a 2 GB limit for ISO files? -
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 17:02 -
dvd decrypter/dgindex question...
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2009, 09:35 -
New to Board DVD Fab HD Decrypter 4 Question
By marine89052 in forum Authoring (DVD)Replies: 3Last Post: 27th Mar 2008, 23:33 -
question about DVD HD Fab Decrypter/Burning
By Bamahusker in forum DVD RippingReplies: 22Last Post: 19th Nov 2007, 11:33 -
DVD Decrypter Region Question
By nickolasj80 in forum DVD RippingReplies: 2Last Post: 21st Jun 2007, 19:26
