I bought a professionally mastered music CD that I tried to rip to my hard drive with EAC. The music is a continual blended mix and (EAC is the only program I know that can rip it in it's original form) the end result was at 98kbs I knew something was not right. So I tried to adjust some settings and try again, this time EAC took so long, over 45 minutes which is very unusual so I had to cancel.
So I decided I better make a copy of the original before I totally damage it. I used Nero 9 and it would not make a copy, I tried the simulation and everything. I think EAC or my drive damaged it's an LG HL-DT-ST CDRW GCE-85278 I have a brand new drive as well, but I am scared to put the CD in my new drive in fear of damaging (the drive) it. I need a copy of this CD can anyone help? I still have the 98kbs copy but that is below standard. Thanks!
Results 1 to 14 of 14
It's also possible that EAC was not properly setup/configured..
http://wiki.hydrogenaudio.org/index.php?title=EAC_Drive_Configuration
And in case you need lame configured..
http://wiki.hydrogenaudio.org/index.php?title=EAC_and_Lame" Who needs Google, my wife knows everything" -
Okay, I downloaded EAC and now need some help in ripping/burning a continuous mix cd that I made. I don't want any gaps between tracks and would like to keep the track numbers that I have already set with my stand alone recorder. I have configured lame and ran the tests.
It Started In Texas -
Keeping in mind sony had a copy protection that was defeated with a 99c magic marker, same copy protection?
Possible, but not likely. Chala - turn the disc over and if it looks golden colored it might be SACD, although it should have the SACD logo on the front as SACDs have to be commercially pressed.
I have a Spanish CD that EAC cannot fully rip. I ended up having to copy the first track via analog to make a backup copy but I was able to get all the other tracks via EAC. So I have personally seen EAC fail to copy a true commercial audio CD. It was a Ketama CD. I think it was "Dame la mano". -
Okay, with some searching I have managed to get my mix cd ripped into one continuous wave file and would like some advice on which program can put the track numbers back into the wave file. I don't want gaps, just want the tracks numbered so I can access any track at a given time. I ripped the cd using EAC (Create Image and Cue Sheet). What to do next?
Thanks guys bottom line, the CD I was trying to burn was part of a retail 8 CD Box Set. It appears to be damaged with errors, cause I am able to burn (AnyCD), and rip with (EAC) the other discs in the Box Set, but not that one. Now I have to examine further and find a good program to check, examine, and possible restore CD's if you know of one please let me know.
MOVIEGEEK are those programs Copy Protection busters? What are they?
Maybe it was copy protected that seemed to be my issue. I find if i keep AnyDVD which i purchased running in the backround it will take out any protection
It's not exactly what you want, but if you use CD Wave (VERY easy to use, but it's NOT freeware) you can set a split point where you want for each track and save them. Just burn them with something like Nero (Nero is fine for audio CD burning - one of the few things it's actually good at) and set the gap between tracks to 0 seconds so no extra space gets added.
Many burners can use the Cue sheet to burn an audio CD, if that's what you want. However, you'll have to look at the Cue sheet and see if it has individual track info or if it's one giant long song that it plans to burn. If it's one long song, you'll have to manually set the track points yourself. Or use CD Wave to break it into individual tracks and just drag and drop those into a new audio CD in the right order and skip the Cue sheet. -
The CD is one continuous song or music set I do not want to separate the tracks EAC works great for what I need!
I have both Any DVD and Clone DVD I used Clone DVD to burn one of the other CD"s in the box set and the CD skipped and paused I think I am going to return my new burner and getting a different brand -
Thanks for the replies to my questions, I will try it out. Doing it with my computer will save me the pain of Real Time (Re)recording on my standalone recorder marking tracks.
It Started In Texas
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12
