Hi,
Is there a method for removing logos from mpg2 videos without having to convert to AVI or VOB first.
I have a series of MPG2 videos that I'd like to strip of their annoying intermittent logos.
Thanks for any help.
Cheers,
Fred![]()
I assume they are in the MPG container ?
There are several de-logoing filters for avisynth, and plenty of guides if you look for them. There are basically two camps on this. One camp believes it is worth the effort, the other believes that the blurry blob left over by the process is worse, or at least no better, than the logo it replaces.
Regardless, you cannot do this without re-encoding afterwards, but you do no have to re-encode or convert before hand.Read my blog here.
Thank you, your advice is a big help. At least I now have some idea of its feasability!
Cheers,
Fred -
Note that some of the examples of logo removing with pictures showing before and after are either best case scenarios that usually don't happen or have been manipulated with something like Photoshop to make them look better than in reality. It is unlikely that you will have crystal clear results where you can't tell that a logo was ever there. In most cases what happens is you get a "blurry blob" that guns1inger talks about. It's up to you to decide if this is better or worse or even worth the trouble to do.
If the logos are semi-transparent, as many TV channel logos, they can generally be almost completely removed.
You make a mask from the logo and the brightness changes are reversed.
I use NoLogo for this.
If the logo is solid colour then you can't recover the obscured image. But you can use a filter that extrapolates in from the edges to fill in the area, like Xlogo. That's the blur the posters above so disdain. Personally I find it less distracting than a brightly coloured logo. I wrote a little guide for this here. And no, I didn't fake the screencaps.
And if the logos are intermittent, I use ReplaceFramesSimple to switch the filter in and out.
Example below. If you can't be bothered, leaving the filter on when the logo isn't there creates a dark shadow. This show had long stretches off as well as on.
Use AvsP to edit and preview.
But you do have to reencode. You don't have to make an actual AVI file, you can load the MPEG into Avisynth or VDub to apply the filter, but then have to save the result to a new file in your format of choice.Code:ConverttoYUY2() src = last logo=ImageSource("logo514.png").ConverttoYUY2() NoLogoAuto(logo,1) ReplaceFramesSimple(src, last, mappings= \ "[694 9323 ] [17766 32079] [32557 39239] [40034 51912] [52683 59975]") ConvertToYV12()Last edited by AlanHK; 27th Jan 2010 at 10:26.
Interesting, looked at some of those pics, that is pretty good. I have some old telecasts that have massive weather warnings that pop up on the screen and run for about 5 minutes. It is pretty bad, in that the fact, these warnings are massive an cover some of the actual picture. Is it possible to remove this?
Sorry, Deter. Those weather warnings are usually a motion crawl across the bottom. Unless the ones you describe are stationary, there's not much that can be satisfactorily accomplished, other than a really bad blur or a complete cropping out of that portion of the picture.
If it was just the bottom that would have been great. However the stupid Mississippi Cable company decided to paste it in to about 1/2 of the picture. This video is one of the all-time classics, that is the part that is upsetting....
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 18:57 -
How to add logo in mpeg videos ?
By ashe09 in forum EditingReplies: 7Last Post: 9th Nov 2011, 03:40 -
By MGadAllah in forum EditingReplies: 33Last Post: 25th Sep 2011, 20:53 -
remove a logo using two videos
By mathmax in forum Newbie / General discussionsReplies: 32Last Post: 20th Sep 2011, 21:31 -
cd-rom stripping
By marinebc11 in forum MacReplies: 4Last Post: 16th Feb 2008, 09:51
