  1. Hi there,
    i have a big problem and i cant solve. Im helping a friend to downsample some audio fil ac3 from 640 Kbps to 384Kbps.
    I tried with beelight and using only the downsample function so...."-azid( -z1 -b1 ) -ac3enc( -b 384 ) "... and i get a file audio with a compressed dynamic (look at second pic, the first is the normal audio and the third is what i get with DaudioK).
    I tried with DAudioK, i get a good file, with no touched dynamic, but the order of channel are no right. I get L-R-C-LFE-LP-LR instead of L-C-R-LP-LR-LFE
    Somebody can help me? I tried many way, bu nothing.
    Original File
    File worked with Besweet
    File worked with DaudioK
    Many Thanks to all
  2. Member midders's Avatar
    Sep 2008
    Try eac3to:
    eac3to input.ac3 output.ac3 -384
    If this doesn't handle the channel orders correctly, then use -1,2,0,3,4,5 or similar to remap them.
