I need to share about twenty or so old movies with friends and family. They are currently stored in DV format and I want to find a tool that can batch convert them all at once (or rather one after the other). My plan was to que up each file with RipBot264 or Handbrake and then let 'er rip. The problem with both of these programs is that they recognize the AR as 1.5 and I the only way I can see to correct the AR to respective 16:9 or 4:3 (there are some of each) is to change the actual pixel count in the output frame. This I do not want to do.
As of now I've tried rendering out a high bit-rate MP4 with Vegas and things look good, but I can only do one at a time.
Am I missing something in RipBot or Handbrake? Or is there another tool I should consider?
most programs assume square pixel, unless specified otherwise
enter the pixel aspect ratio in the custom command box (called SAR or sample aspect ratio in x264 terminology)
for NTSC:
--sar 8:9 = for 4:3 DAR
--sar 32:27 = for 16:9 DAR -
So I've found some interesting things. I've got about 100 DV clips that have been captured with either Vegas' 3rd party capture program OR with Windows Import Video. Those captured with the windows program appear to be properly flagged with their respective PAR's. When I set up a few to be batch encoded to x264 mp4's using RipBot they are all recognized in their proper PAR and the resulting MP4 is perfect. However those captured using Vegas are not flagged. RipBot reads them as 1.5 AR (SQUARE).
I can actually run the DV files through Movie maker with no re-compression and then they seem to automatically get flagged properly and I'm off to the races. But I have 100+ files!
So you're suggesting that I use Handbrake and change the ANAMORPHIC setting from "None" to "Custom" and then input your above settings...correct?
So it gives me four adjustable settings below it.
Modulus
Display Width
PAR Width
PAR Height
When I input your settings (32:27) for the Pixel width and Height if gives me an entirely new display size at the bottom (853x480).
So will this actually add more pixels and just keep them at 1:5 PAR?
Batch processing AVI to MP4 (H.264)
By Ahari in forum Newbie / General discussionsReplies: 39Last Post: 10th Apr 2012, 13:52 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 02:03 -
mp4 (h.264) Demuxing: Is it possible to save a step when encoding to ac3
By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2010, 07:04 -
MP4 AVC/H.264 encoding
By Jacobus Serpenti in forum Video ConversionReplies: 17Last Post: 1st Jan 2009, 09:18 -
batch joining multiple .001 files
By vitamine in forum EditingReplies: 8Last Post: 22nd Sep 2007, 16:57
