Hello,
I am using MainConcept Reference to encode a file output from Final Cut using its QuickTime Exporter (It's a friend's file). The frame rate on the input file is showing "Variable", with the lowest fps at .003 and the highest at 29.97 for an overall framerate of 0.978 fps. MediaInfo says the video portion is ~5min but the audio portion says it's 10sec (which it should be).
This file plays perfectly in QuickTime, but when I encode it with MainConcept to H.264/AAC, it comes out as a 5min file with the video slowed waaaay down. If I take the file into QuickTime Pro and re-export with the same settings (essentially washing the file I guess), then use that file in MainConcept, it encodes perfectly.
I have tried all variations in the H.264 codec settings and have been unable to get the frame rate to come out right. Has anyone experienced a similar issue, or know of a way to get MainConcept Reference to handle Variable frame rate inputs?
Here is the MediaInfo output of the source file from FinalCut (pre MainConcept Reference)
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 32.7 MiB
Duration : 5mn 15s
Overall bit rate : 870 Kbps
Encoded date : UTC 2009-10-07 02:52:37
Tagged date : UTC 2009-10-07 02:52:39
Writing library : Apple QuickTime
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
<b>Duration : 5mn 15s</b>
Bit rate mode : Variable
Bit rate : 820 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 4:3
<b>Frame rate mode : Variable
Frame rate : 0.978 fps
Minimum frame rate : 0.003 fps
Maximum frame rate : 29.970 fps</b>
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.539
Stream size : 30.8 MiB (94%)
Language : English
Encoded date : UTC 2009-10-07 02:52:36
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
<b>Duration : 10s 276ms</b>
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 1.88 MiB (6%)
Language : English
MCR doesn't support variable framerates
You can try to convert to CFR with another application like avisynth , or ask your friend to export a CFR file. I suspect that's what you're doing when re-exporting from QT. If you use a lossless format like animation codec, or uncompressed, you shouldn't lose any quality (except for the colorspace changes and gamma shifts that QT can do)
If your source file is already h.264, why are you converting it to h.264 ? -
Great to know, Thank you! I'm not transcoding as much as changing the resolution / bitrate / audio, since the source is PCM and I want AAC with lower bitrate video in an mp4 container instead of mov. I hope MainConcept decides to incorporate facilities to accommodate this into Reference at some point
Issues Editing Skype's .MOV's in Final Cut Pro.
By macphoto in forum EditingReplies: 1Last Post: 14th Sep 2011, 20:18 -
convert h.264 to use in Final Cut Express. Streamclip problem
By robinhall in forum Video ConversionReplies: 2Last Post: 28th Mar 2010, 15:54 -
convert H.264 to use with Final Cut Express. Streamclip problem
By robinhall in forum MacReplies: 1Last Post: 28th Mar 2010, 15:41 -
264 stream from BluRay into Final Cut Pro?
By QuicktimeSlave in forum MacReplies: 0Last Post: 7th May 2008, 21:26 -
VHS to PC frame rate issues
By ulremember in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2007, 10:58
