Hello people.. Ive been working with subtitles for a few years ( usin dvd architect, the ussual subtitle workshop, and other clasic programs) and now i have an upgrade of the quality needs of my work. The issue is this, i have to add subtiles in a movie. Originally, i have a dvd copy and work with the text in de Subtitle Workshop and i produce the srt file. In other oportunities, the only thing i got to do later is import the subtitle file (in a .sub extention) to the DVDarchitect and that was it, but now they gave me a DVcam copy of the Movie... I captured it with Premiere (as a .avi) and i got to export it to DVcam with the subtitles. Ussualy i make a damm text line after another (a tedious process), but it got to be a way to incorpore the subtitle file (.srt .sub .text or wathever) into the timeline. Its the fukin 2010!! Please help
since you are talking about hardcoding subs, perhaps..
After capturing AVI, open in virtualdub, use the subtitling filter, adjust font/size/position. Verify timing by playing back on virtualdub.
Encode to lossless format with uncompressed audio (PCM). Perhaps Lagarith?
Import resulting file into Premiere/Vegas and encode to DVCam format.
If you install the Matrox VFW codec, then you can generate DVCam AVI right from Virtualdub. -
Yes, clarify, please. You certainly can hardsub a DV AVI movie (permanent, imbedded subtitles) using either the method described by subc, or buy using the titling utilities within Premiere or Vegas. If you want to use soft subs, you need to determine the final playback format. I don't think there exists a DVcam video player with a subtitle feature, but if your final playback is DVD or mpeg-4-based avi (like divx), just subtitle the usual way after you encode the DV-AVI to its final playback form.
And please -- there is no reason to spew childish profanities. -
Tnx people, last year i didn't know even the concept of "hardsubbing". I tried a few programms but the obviuos best result was the virtual dub.
( sorry for the swearing!) -
I find Avidemux is ideal for mp4 hardsubbing & a lot easier than VirtualDub (which I use mainly for subbing to .wmv).
Subtitling in Adobe is like taking a train to pick up a loaf of bread. The day Adobe developers learn to import .srt & .ass (+ 50 other formats) files for immediate rendering will be The Wheel MkII.
Aegisub, Subtitle Edit, VSS + Avidemux & VirtualDub... - all freeware that do what Adobe haven't managed yet.
Anything Adobe Premiere 5.1 does that Vegas Pro 8 doesn't?
By brassplyer in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2012, 02:04 -
Sony Vegas 9 Professional or Adobe Premiere CS4 for PC
By apollo1980 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jan 2010, 15:36 -
Vegas Pro 9 versus Adobe Premiere CS4 ?
By Chrushev in forum EditingReplies: 1Last Post: 23rd Oct 2009, 19:23 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 07:51 -
Timeline Preview - Vegas Pro 8 vs. Premiere CS3
By SCDVD in forum EditingReplies: 2Last Post: 15th Aug 2008, 13:29
