I have an MPEG-4 XVID movie file (AVI) with Audio (MP3) thats out-of-sync
can anyone guide me to fixing this?
much appreciated
thanks
Results 1 to 15 of 15
does it come early or late? and is the delay constant? If it's a constant delay, find the audio shift value in your media player (e.g. +/- keys usually shift the audio) , and use avidemux to enter that audio shift delay
is it in sync and then gets progressively worse? If it's progressively worsening, it means the audio & video lengths don't match. You could either shrink/expand the audio or video (change fps) to match
are there glitches? glitches can cause desync errors. These are tough, you often have to cut the video into segments and process it manually by section -
thanks...
the audio starts in sync THEN falls out of sync maybe by about 50ms at end but cant be sure how much....
how could I expand the audio?
thanks -
thanks - i will try
this is too play on TV so may not play 'odd' frame-rate (DivX 7 codec)
so how do I remove audio then tmux it back in when done?
Format : AVI
File size : 1.35 GiB
Duration : 1h 57mn
Overall bit rate : 1646 Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDub build 30091/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Muxing mode : Packet Bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 57mn
Bit rate : 1540 Kbps
Width : 624 pixels
Height : 336 pixels
Display aspect ratio : 1.857
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.294
Stream size : 1.26 GiB (94%)
Writing library : XviD 50
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 57mn
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Stream size : 80.4 MiB (6%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms -
you can use audio=>save in avidemux , fix the audio, then remux either with avidemux or avimux-gui .
If you don't know the exact ratio or numbers, it might be easier to adjust the frame rate of the video by small increments, using avifrate , or vdub .
Here is a guide (scroll down)
http://www.gromkov.com/faq/faq2004-0064.html -
From what you 've told me, there is no delay at the end. It begins in sync, then gets out of sync. This suggests a mismatch in a/v length
If your hardware doesn't play "off" video frame rates , the only way to do it is to fix the audio instead of the video
I don't know of any way except by trial and error. Sometimes you can get the ratio from mediainfo (the duration of the video & audio) , but in your file, it is the same. You could use the avifrate with some trial and error , to find the ratio, then use that in audacity. Avifrate is much faster to use, than resampling & re-encoding audio many times for trial and error -
i meant the delay between the audio and video near end so I know how many MS to adjust the length by in audacity... I have the MP3 loaded in AUdacity... is there anyway of playing the full movie fle and finding out the delay near end or is it just GUESS work.... remux then see if it worked?
also that guide you linked to is outdated and links to programs no longer work... (AVI FPS CHANGER)
You wouldn't change it by 50ms , you would change it by the fraction. So you need to know the durations in ms. e.g. If a video was 60s and audio was 59s , you would stretch the audio by 60/59
Click the hotlink for avifrate
https://www.videohelp.com/tools/AVIFrate
EDIT: The links for that guide are working for me. That program is slightly different than the one at videohelp, but the idea is the same
frateadj100.zip -
You can try this in Audacity. Using the 'Change Tempo' effect, click on the Length (Seconds) 'to' box and enter the desired length. Save out in a compatible format for your audio. Add this back in with your video. I use VirtualDub for this and set both video and audio to 'Direct stream copy', and disable/delete the old audio, then save it all with a new filename if you don't want to overwrite the existing file. This will 'mux' your new audio file with your video file. Only takes a short time.
The hard part is determining the correct length of the audio file to sync with the video file. If the video file is corrupted, then it gets much more complicated as you may have to chop up the video and treat each part separately, then rejoin.
You usually can't fix this. It's not a simple issues of stretching audio.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
merging two video clips together + sync-ing? (with examples!)
By arthritis in forum Newbie / General discussionsReplies: 2Last Post: 18th Sep 2010, 06:23 -
How is YouTube id'ing copyrighted audio immediately?
By brassplyer in forum Video Streaming DownloadingReplies: 3Last Post: 8th May 2010, 19:05 -
Dj-ing help. How to do it?
By foton in forum Newbie / General discussionsReplies: 6Last Post: 11th Sep 2009, 17:10
