I recently download the nimo codec and it plays my movies fine, but I can't seem to convert it anymore... I use virtualDub and it says something like can't recognize the audio or no audio.
The reason why I download and installed the codec is because without it I can't play the movie with sound. (ocean 11)
can someone help?
its not that u cant convert BECAUSE of the codec the codec didnt mess up your Vdub, its that Vdub doesnt work with that particular film because it uses that codec, which is unsuported by Vdub...
I got the same problem, but with the OGG codec... -
I installed the newest NIMO codec pack and after installing it TMPGenc would not let me Merge/Edit. I don't blame the Codec pack, it just conflicted with other codecs on my computer. Namely Stinkys MPEG2 codec. Also some of the filters may have been the culprit.
Anyway I unistalled the pack then reinstalled just a few that I may need, such as the audio codecs. -
I install only the audio codec I need, and ever since can't use VirtualDub...
Any other programs that can reconvert to DIVX TO VCD???
Ocean and harry are the two mov with trouble from sharereact.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 03:33 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 22:53
