Ok, I have about a 1 hour and 20 min home movie that I'm trying to encode. When I encode only a short region (ex 1 min) the output video plays perfectly with audio and all, but when I encode the entire hour and 20 min video, there is no audio. At first, I was thinking that I had some missing codecs or something, but that wouldn't make sense because the video played the audio when I encoded a short part. Also, I tried importing the output video back into vegas, and it shows that it has an audio track, but it is flatline the whole way through. Any solutions?
The first question is does the whole video itself play the audio in the first place. If it did you can try encoding the audio track by clicking on the audio in the timeline and a rick clicking on it, choose "Apply-Non-Real-Time-EventFX" from the popup menu, then choose "ExpressFX Audio Restoration" from the list and adjust it a bit.
all the audio and music works perfectly playing from the timeline, but after encoding, no audio
i think the problem is with encoding for long periods of time and not with the audio tracks for the individual clips. like i said, when i render short loop regions, the audio is fine, but rendering all of it, there is NO audio. same settings and everything between the two.
Problem with importing audio from movie track - Sony Vegas Pro
By tooninoz in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2010, 01:39 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Sony Vegas Pro 8.0 : Problem to encode audio file into mp3.
By flash_49 in forum Video ConversionReplies: 0Last Post: 20th Jul 2010, 07:21 -
sony vegas audio
By romik91 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 16:37 -
Sony Vegas audio stream problem
By PoT in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2007, 14:35
