Here's a 720x576 DVD file that - according to PowerDVD - is supposed to be stretched for 1024x576 to maintain a 16:9 ratio. MediaInfo though claims it's 2.35:1 (CinemaScope).
I have at least 2 separate DVDs with this issue. Both of them are commercial Israeli films which may be the common ground.
Anyway, my question is just this - how do I covert it to Mpeg1 (to be embedded in PowerPoint in remote computers) via TMPGEnc 2.5 while keeping it 16:9?
TMPGEnc accidentally detects 4:3 for both "Aspect Ratio" and "Source aspect ratio". Manually supplying a 16:9 525 line (PAL) for both [+"Full screen (keep aspect ratio)] actually makes the result look like 4:3. So far, the best result came from leaving the 4:3 525 line (PAL) for "Aspect Ratio" and only changing to 16:9 525 line (PAL) in the "Source aspect ratio". But that means letterboxes in PowerPoint's edit mode (even if I choose 16:9 page layout). This may be fine, but I still don't like having to choose 16:9 just for the input.
http://rapidshare.com/files/340361615/720x576_but_wider_DAR.MPG.html - 6.19 Mb
IIRC, there are other setings than ""Full screen (keep aspect ratio)" in
TMPGEnc --- and also, those settings work differently for MPEG-1 encoding.
P.S.: Not to mention that many/most/all DirectShow MPEG-1 decoders
(I'm supposing PowerPoint relies on them) do not support correctly video
resolutions different than 352x240/352x288, nor Aspect Ratios different than
4:3 and "1:1" (square pixels).
P.S.: There exist other freeware MPEG-1 encoders, such as QuEnc,
mpeg2enc, ffmpeg and mencoder --- I think you should give them a try.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
