I have a movie that has the audio in sync the whole movie until the last 10-15 minutes of the movie and then it goes about a second out of sync. I have done some searching and all the ways i found to fix out of sync ac3 audio only works if the whole movie is out of sync, not just one part. Does anyone know the best way to fix the ac3 sync delay at the end of the movie? Thanks in advance!
Find the point at which the audio goes out of sync, split the file into two parts at this point and adjust the audio in the second part until it is in sync. Then rejoin the two parts.
The tools you use to do this will depend on the format of your original file; for avi files I recommend Virtualdub.
Slainte
middersVolunteer for https://www.computersforkids.org.uk/
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 08:40 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
By tarrantm in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 21:56 -
sync ac3 from dvd to mkv hd video
By tertill in forum AudioReplies: 2Last Post: 1st Nov 2007, 15:46
