Results 1 to 9 of 9
    Feb 2009
    On the computer in the home office, keep getting an error message: The instruction at "0x00f3f7a5" referenced memory at "0x7e41950f". The memory could not be "written". It gives the options: Click OK to teminate or cancel to debug the program. No matter what I push, it starts a timer that restarts the computer.
    Feb 2008
    Twin Peaks
    The MBLASTER virus also shut peoples computers down, but that message was labeled under "NT authority". Assuiming your computers memory is not at fault, which it could be, start ->run -> shutdown \a should stop your computers countdown timer. If that doesn't work try chaning the \ to a / my switches are not 100%. You can test your computers memory using "memtest 86+" from Microsoft.
  3. Originally Posted by mac71671
    did u google the error msg?
    check this link I'm not sure if it's the same issue u are facing
    http://answers.yahoo.com/question/index?qid=20100121111917AAbL5R9
    There are 3 step to repair window svchost.exe application error
    I think your computer is already very dangerous, and you should fix it immediately. I had the same problem with you, it bother me for a long time. I have searched many ways online and found that the following method is the best, my friend had window svchost.exe application error too, he also quickly fix window svchost.exe application error with the following method. I think you should try it, I hope it can help you:
    1: Download a window svchost.exe application error repair tool,install this error repair tool.
    2: Open window svchost.exe application error repair tool and scan you computer for free
    3: Then click the Repair All Button again and your done! It is very easy to repair window svchost.exe application error.
    Here are the url of window svchost.exe application error repair tool:http://www.RepairErrorSoon.com/ttfix-window_svchost.exe_application_error-zz0001
    Source(s):
    Feb 2009
    Sounds like i need a registry cleaner. Is there any that is free? Ive downloaded 2 "free" registry cleaners so far. After I ran the scan it then asks me to buy.
    Feb 2008
    Twin Peaks
    try cccleaner.
    Feb 2004
    Australia
    Windows Xp in system profile
    1: Is sp2 , sp3 installed
    2: Name of antivirus product being used
    3: Any secondary firewall products installed
    Advanced windows care free version includes all the default components you might need ... includes backup before any changes are applied
  7. Gamer and Builder HotDamn!'s Avatar
    Nov 2009
    ccleaner does the job, free!
    http://www.ccleaner.com/
    good luck!
  8. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    It wouldn't hurt to run Memtest 86+ on your memory; download the ISO, burn it to a CD and reboot with the CD in the driver. Free.
    Feb 2004
    Australia
    http://www.pchell.com/support/svchosterror.shtml
    As for those links in Mja's post lower down ... those app's are junk and avoid like the plague
    As for the ms support there appears to be a lot of similar complains and users using combofix
    http://www.bleepingcomputer.com/combofix/how-to-use-combofix ... read carefully
    Wise thing would be to image the system using macrium reflect before letting loose with such repair tools ... if it goes pear shape you can restore the system prior to the repair attempt stage and continue the search
