I'm beginning to use Final Cut Pro and I have to work with many sd cards avchd canon.
I created on my hd several folders (data1,data2, etc) and I put the entire content of the sds on every folder.
When I try to import the files in Final Cut I use the "log and transfer" option.
I succeeded to do it with 7 out of 9 folders, without problems.
With the remaining 2 I'm not able to import them and Final Cut exits immediately, maybe there's something wrong with the directory structure, even if it is exactly the same as the other folders.
How can I fix this?
Is there any software capable of restoring possible structure problems?
Is there any other way to bypass this error?
Giovanni
Results 1 to 1 of 1
Giovanni Gagliardi
AVCHD in Final Cut Pro: am i doing it right ?
By stacks in forum Video ConversionReplies: 1Last Post: 8th Sep 2010, 05:07 -
Final Cut Importing Woes (non-DV files)
By panhype in forum MacReplies: 2Last Post: 15th Jul 2009, 16:20 -
Strobe importing VHS to Final Cut Pro
By Huntr777 in forum MacReplies: 0Last Post: 15th Apr 2009, 14:59 -
Importing DVD Files for Use in Final Cut?
By The Monkees in forum MacReplies: 8Last Post: 29th Dec 2007, 09:20 -
importing commercial DVD's to final cut
By aquafinity in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2007, 16:31
