I've been trying for several weeks to convert (via MeGUI) this 1080i/29.97-captured TS file (well, 3 parts actually) I've tried to IVTC to 1280/720/24fps, or leave it as 29.97 and go to 1280 from there, but regardless of how I go about it, I still seem to get jerky, inconsistant motion. I even looked into the specifics of the cameras used for it (Arriflex D-20), which seemed to indicate that the end result could be native to film OR video.
Has anyone else dealt with this, and/or was able to get a working conversion?
	Was this a TV cap ?
 I think some networks do time shifting or drop frames and other sneaky tricks to squeeze more commercial time in
 Maybe post a sample and someone will have a look at it
	Yes, a transport stream rip from Universal HD...
 Here's a short clip, which has pretty much been the absolute indicator whether I have the right script or not. What I've also found is that, even after I'd used on that APPEARED to work, I'd run it on the whole show, and... it wouldn't work on the whole show.
	So, anyone had a look, and/or is able to offer a suggestion? The problem may be related to the fact that we know the camera model used in filming, but dont know which format or mode it was set to output.
 Suggestions, anyone?
	It's normal 3:2 pulldown, bottom field first. There should be no problem with IVTC.
 In AviSynth:
 orMPEG2Source("TEST.d2v")
 TFM()
 TDecimate()
 Quick lowres Xvid AVI:MPEG2Source("TEST.d2v")
 SeparateFields()
 SelectEvery(10, 0,1, 2,3, 5,6, 8,9)
 Weave()Last edited by jagabo; 20th Mar 2010 at 17:02.
  Simplest way to convert 1080p h264 mkv to 720p mkv?By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 11:16
  Best quality option to convert 1080p mkv to 720p mkvBy carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17
  25fps 1080i mkv convert to 24fps 1080p or 720p mkv?By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 10:57
  How to convert mkv to ps3 viewable format maintaining mkv subs in new file?By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17
  Convert Iron Man BD to MP4 using RipBot - Audio Channel IssueBy csilvest in forum Blu-ray RippingReplies: 5Last Post: 27th Jan 2009, 11:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
