What is a good VirtualDubMOD replacement, i'm talking about the feature of encoding multiple audio streams.
in other words:
Which software is the best to make Avi's with multiple audio tracks, BESIDES VdubMod? And Avidemux don't work for me, been there, done that.
Or, how to make Vdub (normal) store and encode multi audio???
	Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	AVImux GUI won't encode the audio for you, but if you have the streams, it will add them. Also does subs and a good range of video and audio formats. Read my blog here.
	Encoding AND adding is key for me, so no.
 i'm trying automkv now, but I guess cos it's not really intended for this sorta work, it's really slow, and it seems to do a lot of unnecessary crap. i think i might give either avi.net a try or mediacoder.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	If you want the final output to be AVI, why use AutoMKV? Doesn't it output MKV/MP4/WMV?Originally Posted by ********
 If you want multiple audio tracks, you should use a modern container suited to it, like MKV.
 You can use any tool to encode the audio streams (eac3to gui, MeGUI, whatever) and then mux them all together with MKVmergeGUI (or an AVI muxer of your choice).
	I kinda rest my case, seems you've answered your own question. I mean, if you think using an MKV merger/muxer is bad, why recommend one? ...Originally Posted by creamyhorror
 Of course, I might me mistaken about the nature of those 2 apps, but I don't think so.
 Megui is really overly complicated, there's no easy guide with pictures etc. I need serious handholding for that one.
 AutoGK, WinAvi, they come close but they all fail on being able to accept precise settings, no 112 mb/s for audio, no 704*384 size. Maybe these are a little exotic, but hey.
 Any other ideas, please?Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	I think you misread my post. I simply said, if *you want AVI*, then it doesn't make sense to use AutoMKV. If you want *multiple audio streams*, then you should use MKV instead of AVI, mainly because MKV is a more modern container whose multiple-audio-track support is basically guaranteed among players. Using an MKV muxer is *good*.
 If you want to go with AVI, use AVI-Mux GUI to do the muxing as guns1inger suggested. You have to encode the audio and video streams separately. You should be able to do that in Vdub...I think.
  Multi-Audio Stream to Multi Device HappinessBy ebobster in forum Video ConversionReplies: 0Last Post: 15th Nov 2011, 02:18
  How to convert mkv to dvd with multi-audio track and multi-subtitles?By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 15:21
  Multiple steps to create multi-audio, multi-subtitle DIVX from DVDBy schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01
  Looking for DVD player replacement - Good DVDR media support? (~£50)By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12
  any good tools MKV -> AVI with multi-track audio support?By helloguys in forum Video ConversionReplies: 1Last Post: 18th Nov 2007, 12:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
