OK, i have finally made the temps for svcd-x
please note the following before using these-
use 80 min cds only
use tmpgenc v 2.52 plus only(it uses the new 2 pass vbr mode which keeps movie 1-6 mb under max size!!)
There are about 85 temps.
Why so many?
I'll tell u-
each temp has of course a name and each name has 1 valuable info u need to know
Each temp is made for a diff time length of movie
the lowest is 40 min and the max is 2 hr.
if ur movie goes over a few sec of time, for example-
if ur movie is 90 min 30 sec, should u use the 90min or 91 min temp?
Here are ur choices-
if u use the 90 min, u will have about 8 mb free on cd, if u use 91 min, u may have to overburn, which if u can, go ahead.
These temps are made for the settings i use and 1 more important thing-
These temps are to use ONLY for dvd rips in d2v or avi ONLY.
If you have mpg svcd dvdrip, you will need to go into the advanced tab and change the Y value of the res size from what it is to 480.
thats it. I'm not goin to upload them to baldrick just yet but i will.
If you want em, IM me only!!!!!! on MSN messenger only for right now.
locooverrider@hotmail.com
Results 1 to 1 of 1
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one.
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 21:30 -
finally my mac
By scarlac in forum DVD RippingReplies: 5Last Post: 23rd Apr 2010, 02:54 -
Laptop Temps
By HotDamn! in forum ComputerReplies: 4Last Post: 17th Apr 2010, 01:29 -
Phenom 9550 temps
By Illusionist in forum ComputerReplies: 3Last Post: 14th Jul 2008, 14:06 -
BD+ finally cracked...
By ntscuser in forum Latest Video NewsReplies: 12Last Post: 25th Nov 2007, 07:14
