I am using Pinnacle Studio Ultimate 12 to edit my DV footage (AVI). But I don't want to use Pinnacle to encode it since I know there are much better encoders out there.
So after using Pinnacle to edit movie content, do I just output it to an avi file using "Uncompressed Frames" as the compression method and then use a much better 3rd party mpg encoder to create the mpg file with top quality and then a 3rd party dvd authoring program to create the VIDEO_TS folder (and then burn it)?
Or should I be selecting some other setting? (The "Compression" drop-down lists DV, MJPEG, a few other codecs, and Uncompressed Frames).
Results 1 to 9 of 9
Normally you should output back to DV format (DV-AVI). Use an encoder that accepts DV format.
Uncompressed AVI will increase the file size 5x and convert the chroma.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
So select "DV" from the Compression drop-down box and then take the outputted (& edited) AVI file to my favorite MPG encoder?
YesOriginally Posted by spup345Recommends: Kiva.org - Loans that change lives.
Only choose DV if it stream copies. Otherwise you're losing quality from Dv compression. Go with uncompressed for non stream copy. DV is lossy.
What he means is if your editor does "smart rendering" ; i.e. it allows pass through of cuts only editing, or "stream copies" untouched segments
Some editors will decompress to RGB internally anyway , so the chroma will be resampled (interpolated) anyway. If this is the case with your editor, then DV is lossy and your quality will be worse.
However, as soon as you add effects, or color correction, it undergoes an YUY2=>RGB conversion anyway.
To summarize, exporting DV-AVI is only better in the case that your editor does "smart rendering" and allows pass through , and you never did any effects like color correction that affect the entire segment. Otherwise, uncompressed is almost always better (at least in terms of quality) -
Premiere and Vegas pass DV and in some cases MPeg2 losslessly (for unprocessed frames) but Pinnacle Studio may convert everything to RGB so, if true, I agree with poisondeathray.
Note that uncompressed will be large (~65-80GB/hr.) and unplayable without a RAID. You would just feed it to your encoder. DV (13GB/hr) would be more practcal for archive in most cases.Recommends: Kiva.org - Loans that change lives.
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 21:02 -
"Capturing" DV footage - does software matter?
By spup345 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2010, 19:43 -
Sony Vegas 9.0, AVCHD/mds "ghosting" with Canon HG10 footage
By Woodserr in forum Video ConversionReplies: 33Last Post: 29th Jul 2009, 22:12 -
is there an free "anyfile to uncompressed/lossless" solution?
By squadjot in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2008, 13:20 -
Picture "rolls" when trying to grab 60hz footage
By scully1888 in forum Capturing and VCRReplies: 4Last Post: 21st Dec 2007, 04:41
