hi im using the all in 1 guide to diuvx -vcd conversion ive dwnloaded all the tools tmpgenc-vcd easy and virtual dub, also divx 3.11 and divx4.11
so ive downloaded a video in mpeg go to virtual dub open file then video file, then it says select file and file information and note the fps but file info is not lit up in the list so ignored that did next parts ok till i got to click on file and save wave ,same again waves not highlighted so were am i going wrong thaks lads chelly.
It may be me but I have no idea what your asking?
Please explain -
I am confused too.
OK. If you're loading a mulitpart avi in Vdub to strip out the wav for the audio, go to FILE, OPEN CLIP and select the FRIST clip. To add the next clip SEQUENTIALLY go to FILE , APPEND AVI, load clip 2, for clip 3, FILE< APPEND AVI again, etc etc
After you have them all loaded, go to AUDIO, CONVERSION, choose 44100, stereo, 16 bit.....
go to FILE / SAVE WAV
then Frameserve vid stream if you'd like to TMPG.
Look at Baldrick's DivX to VCD Guide, as well as Vdub Frameserving Guide - I believe both are under conversion (to the LEFT)~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
