Results 1 to 12 of 12
    Aug 2006
    I have an AVI file of an old and unavailable movie that is at 29.97 fps. On examining the I find that every 5th frame is a blended frame of the 4th and 1st in the next series of 5. It is not a duplicate frame but a duplicate of two frames combined. I tried to decimate it using Tdecimate. It would decimate to 23.976, but it wouldn't decimate the frame I wanted to decimate. So good frames were being decimated while the blended frame remained. I tried different modes with and without TFM to no avail. Is there a way to do this? Please explain clearly and don't assume I know a lot, because I am not that good at this and need to get the idiots version.
    The film is called Dangerous to Know
    Here is a mediainfo
    General
    Complete name : G:\completed torrents\Dangerous.to.Know. audio fixed 1938.XVID-cg.avi
    Format : AVI
    File size : 700 MiB
    Duration : 1h 10mn
    Overall bit rate : 1 393 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format : MPEG-4 Visual
    Format profile : AdvancedSimple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Custom
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 10mn
    Bit rate : 1 269 Kbps
    Width : 560 pixels
    Height : 416 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.182
    Stream size : 638 MiB (91%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format_Settings_Mode : Joint stereo / MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 10mn
    Bit rate mode : Constant
    Bit rate : 112 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 56.2 MiB (8%)
    Alignment : Split accross interleaves
    Interleave, duration : 33 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
    Here is a clip:
    dangerous%20to%20know%20clip.avi
    Oct 2005
    666th portal
    you do know asking for help with illegally downloaded copyright material is against the rules? and uploading some of it here is not going to win you any points.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Buy the movie,do not post warez or upload samples of it.Please read our rules.
    This seems to be a "public domain" movie so reopening thread.
    canada
    I check all around the web and couldnt find any evidence whether or not its still copyright or public domain but considering it was rated a b movie i dont think paramount would renew it,
    Jan 2007
    Republic of Texas
    From IMDB: "One of over 700 Paramount Productions, filmed between 1929 and 1949, which were sold to MCA/Universal in 1958 for television distribution, and have been owned and controlled by Universal ever since."
    That doesn't determine whether or not the film is PD, but since it's a 72-year-old, hard-to-get, B-movie, I think we can cut the OP a little slack in this case.
    The question is, are the scene-change frames with the combined fields really that noticeable when the movie is played at normal speed? I looked at the avi clip, and it didn't bother me.
    Nov 2009
    On the clip you attached you can use an avisynth script like this:
    avisource("dangerous to know clip.avi")
    selectevery(5,0,1,2,3)
    For the full file you might need to adjust the last 4 numbers to 1,2,3,4 or 2,3,4,5 or 3,4,5,6 etc. depending on which blended frame is the first one of the clip
    Aug 2006
    thanks, this worked well. Is there a link where I can read about this command?
    Nov 2009
    The documentation for avisynth should have been installed on your computer when you installed avisynth.
  10. Originally Posted by fred3f
    It works only until the scene change at the end when the pattern changes and you keep the blend and lose a unique frame, making it play jerky. Are you saying that it works for the entire movie, or just for the sample (which it doesn't entirely)?
    http://avisynth.org/mediawiki/Select
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    it's not public domain
    Dangerous to Know (1938) More at IMDbPro »
    advertisement
    * One of over 700 Paramount Productions, filmed between 1929 and 1949, which were sold to MCA/Universal in 1958 for television distribution, and have been owned and controlled by Universal ever since.
  12. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    The wiki: http://avisynth.org/mediawiki/Select
    If the select works for the whole movie, you're okay, but it might go out of sync.
    If so, there is a script function that detects and removes blended frames that you can try:
    AVISource("dangerous to know clip.avi")
    Srestore(frate=23.976)
    That's also in the wiki: http://avisynth.org/mediawiki/Srestore
    However, you need to install some other plugins to make this work.
    The documentation is rather cryptic, I really can't understand half of it. There may well be a better way to get it to IVTC after blend removal, but simply specifying the output framerate as above did work; though it left one blend in the clip, in a section with blurred background so it was difficult to detect a blend perhaps.
