Hi,
I have this old Panasonic PV-GS50 MiniDV camera which I use occasionally. I have always wondered why the recording playback on the camera LCD and through AV-out produces colorful and bright picture, but when I playback the footage captured via FireWire unsing Premiere 2.0 on the PC its almost black-and-white, very weak colors, everyting is dull. Why such difference?
I have installed pvdcodec.dll which comes with this camera (I downloaded it from camera support downloads).
Maybe I need some other codec as well? Maybe it a completely different issue?
I want to put together some videos on Premiere but I cant get past this ugly look of what I see there.
How do you have Premiere setup and hookup up to?
PC monitors use different levels (0-255) than TV's (16-235) for luminance Y'. The 16-235 corresponds to 0-100 IRE in Premiere's waveform monitor. <16 and >235 (or <0 , >100 are "illegal" for video)
If you are using premiere, it should be hooked up to a calibrated reference TV, assuming your goal was something for TV (like DVD)
If you color corrected or adjusted it accoring to the PC monitor , without the aid of your scopes, the blacks would be crushed and whites blown out when watching on a DVD/TV. -
I have my old PC (AMD Athlon2500+ if I recall, Nvidia 6800GTS etc) and Sony Trinitron 21 inch CRT display. Thats it. I thought you dont need any special setup with capture cards and stuff because its already digital stream coming in through FireWire. The rest is just software.
I know the computer screens are not very suited for viewing video material on them but I have this CRT exactly because I use ir for watching movies (Xvid, DivX, etc) it shows better picture than LCD.
Ok I have then this true-color HP-2335 LCD which is supposed to have the right colors because its S-IPS panel, I just connected it and checked, well it looks a bit better now. But still, I want to point out that the Composite output directly from camcorder beats everything I have ever seen on PC ever. I cant really explain. Maybe it has to do something with that chroma-subsampling, because on computer I can clearly see that some colors are too bright and some are too close to gray, and colors are somewhat washed out, looks like they "float" around abit..
I became really upset with all this issue because I had recently filmed a tape in snow and probably because of this high contrast environment this issue becomes worse and really visible. And probably the white balance was set to God knows what..
Burn your edited video to DVD or send it back to your camcorder and view it on a proper video (TV) display. Compare to the original. As mentioned above, PC displays will make video look washed out and dull. Even a cheap TV will look better. If you have a dual output video card with S-video/composite then you can use a standard TV as a secondary display for your PC and put the video window in Premiere on it. I have my system set up in a similar way though with a true video monitor rather than a TV. Nevertheless, even without a calibrated display, it will look much more faithful than a PC display.
John Miller
Media Players Handle mini-DV (dvsd) Format?
By webpa in forum Media Center PC / MediaCentersReplies: 9Last Post: 3rd Apr 2011, 00:03 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
Problem with importing from MiniDV to HDD. NTSC maybe ?
By antoinel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Sep 2008, 16:44 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 21:46 -
ColorSpace for commerical DVD's
By mlong30 in forum EditingReplies: 6Last Post: 29th May 2007, 20:16
