Results 1 to 24 of 24
  1. Member Ennio's Avatar
    May 2005
    Netherlands
    Hi everybody
    It's been a long time since I'm doing video- and audiostuff. But, I'm back at it again and - because of my positive experiences here in the past - glad to be here at the forums again. Before posting my questions, first this is what I (think I) know / or have learned. If something that I (think to) understand should be not correct or complete, please let me know.
    On PAL dvd's there is this speedup when the source was 23.976 fps from film, right? (To be exactly, I learned that the exact framerate of film is the outcome of 24000 : 1001, which gives 23.976023976023976023 etc.) A consequence of these PAL dvd's is that audio is played back at not only faster speed, but also faster pace and higher pitch. Now, I want to reverse this speedup for some dvd's. (I simultaneously wonder what video-files or media I can best choose to create as going back to "NTSC" dvd format will suffer resolution-loss. Maybe a good time to start and learn how to best upscale and create 24p blu-ray?)
    So, for sound, I think: I perform a timestretch to get audio back at it's original length, pitch and pace. I think the stretch-ratio should be: the outcome of 25 : (24000 : 1001) which gives 1.042708333333 etc. This number I read somewhere else on the internet. I tried "frameserving" (this term I don't fully understand yet) with Belight/Besweet but eventhough the length of the audio seemed the right amount longer, the pitch didn't fall back and audio quality is poor. I now use Adobe Audition on trial.
    Now, for video, I am not sure I understand this frameserving thing. My guess is this: when I do a "frameserve" on a videostream from 25 to 23.976023976023976023, all a frameserver does is "telling" the videostream it should play THE SAME frames at another speed (by "flags" or what?). Because, I want to use the same frames (shot on the original film) right? But just to go back at it's original speed/fps.
    Some questions:
    Audio - Is this way of stretching the best thing to do? I am not sure, but on some occasions the audioresult seems not what it should be on reverbs and other stuff (just seems to sound not right). Is there other/better software than Adobe Audition you would advise?
    Video - Since I am no command-line guy, but shure want to know what I'm doing exactly, what software would you give me in consideration for video frameserving? I strongly wish to learn about what frameserving exactly does. What would you advise me? In the Guides section it only gives how-to-frame serve with software, but not what this subject is really all about.
    Some trivial interests - Is NTSC source exactly 30 or 29.97 fps? And, maybe, why? Has it something to do with the AC power frequency in the USA?
    Can anybody tell me how this "24000 : 1001" framerate on film came to be? (Why not just 24?)
    Again, if you have any advise, additional or corrective thoughts, I appreciate if you'd teach me. I just want to get the hang of all this.
    Thanks in advance for your time
    Ennio
  2. Originally Posted by Ennio
    I use BeSweet and one of its presets to slow the audio and and produce a PCM WAV file, followed by a reencode to AC3. Others do it all in one step using eac3to.
    Most people frameserve using an AviSynth script with the line 'AssumeFPS(23.976)' or similar somewhere in the script. You open an AviSynth script in your favorite MPEG-2 encoder just as you would a video. Go to www.avisynth.org and start reading. Also get and read all the docs that come in the DGMPGDec package. They'll expain all about frameserving and how to do it.
    NTSC DVDs and broadcast TV shows are 29.97fps (actually 59.94 fields per second.
  3. Member Ennio's Avatar
    May 2005
    Netherlands
    Wow, quick reply thanks manono.
    As to the audio part: I always take the highest quality audiotrack available on the dvd and first convert it to PCM wav - if I didn't choose the pcm track already in the first place - and then do the stretch. I will again take a look into besweet and eac3to. My ears will tell me what's best though.
    I will get into AviSynth and the DGMPGDec things.
    Lots of work already. Nice Thanx
    Ennio
    canada
    You can use vob2mpeg to get the main file then load the mpg into eac3togui and use the slowdown 25>24/1.001 to encode the ac3 and if its 5.1 ac3 then it will re-encode it to 23.976 5.1 ac3.
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    Thanks johns0
    Will try this out too. Curious what the sound quality will be though and what it does when the source is pcm wav or dts?
    Lots of finding out to do
    cheers
    Ennio
  6. Originally Posted by Ennio
    Lots of work already. Nice :-) Thanx
    Ennio
    If you convert to PCM, open the file up in Audacity. If the PAL audio was pitch corrected, then use Change Tempo (changes tempo without changing pitch) and enter -4.096. Save the new wave and run it through an AC3 encoder like Aften or an AC3 plugin if you have an NLE program. If the pitch was sped-up with the framerate, then the 25000 to 23976 option in BeLight (or one of the other BeSweet GUIs) is good.
    TFM Audio Tool just added pitch scaling but I've just downloaded it and haven't tried it out yet.
  7. Member Ennio's Avatar
    May 2005
    Netherlands
    Hi guys
    A fast update.
    Wow! This frameserving thang is something else. Have to get into avisynth but here is what I tried out to get 24p video from a telecined dvd...
    For try-out, I loaded a small piece of extracted MPEG2 video (29.976 fps) from a dvd into DGMPGDec. In Video-->Field operation, I chose Forced Film. Saved the project. Now, as I understand correctly, this will take care of the inversion of Telecine (29.976 to 23.976) right?.
    Created a simple AVS script as in the quick start guide and loaded it in VirtualDub. In Video--> Framerate, I chose Convert to fps: 24. Then saved as AVI. And indeed, GSpot tells me the AVI result was 24 fps. Only wonder why it doesn't say it's progressive? It's 24 fps?? I mean, isn't the inverse telecine thing in DGMPGDec taking care of bringing back the video fields to it's original - progressive - frames (no matter what the framerate for now?)
    Question: This framerateconversion in VirtualDub will not re-encode the video, does it?
    Is this a proper way to do it (regarding I have to get into Avisynth yet, because I have the feeling that this IVTC and framerate conversion can be in the avisynth script as well, so I can do all in one.)
    But hey, for now, thanx to all who reacted. Will get into Avisynth further.
    Cheers
    Ennio
    Edit: as for audio, I think it's no problem anymore now to stretch/frameserve (25 --> 24 or 23.976) sound. Have to still find out though what sounds the best.
  8. Originally Posted by Ennio
    Yes and no. It depends on whether or not it was encoded as progressive 23.976fps with pulldown flags or encoded as interlaced 29.97fps. When you run the Preview in DGIndex (File->Preview), if it says Film and Progressive, then you're pretty safe in choosing Force Film.
    If you're going to go AviSynth, go all the way and do all your filtering in AviSynth. Then you can use Fast Recompress in VDub and the encoding will go much faster and the output will be of slightly better quality.
    Once you have it at 23.976fps, why change it to 24fps? It's not as if you can tell the difference. If you insist on doing that, you can add ChangeFPS(24) to the script when reencoding which will change the framerate to 24fps by adding a duplicate frame every 40 seconds or so. The video will stay the same length and the audio won't have to be stretched. If you want to speed it up to 24fps, then add AssumeFPS(24) to the script, but then the audio also has to be speeded up.
    Yes, it's progressive. GSpot won't say one way or the other, but if you open it in MediaInfo it'll say progressive.
    No, it doesn't reencode, but it's still a silly thing to do. In my opinion. When using an AviSynth script though, you have to reencode.
  9. Member Ennio's Avatar
    May 2005
    Netherlands
    ........ When using an AviSynth script though, you have to reencode.
    Hey, is this a contradiction?
    If I insist in (okay, very slightly) speeding up from 23.976 tot 24 fps you say to add in Avisynth script: "ASSUME FPS(24)"
    After that you say ........ When using an AviSynth script though, you have to reencode????
    Isnt's this "ASSUME FPS(24)" in Avisynth a 23.976 to 24 framerserve then? (so, NO re-encodeing, just doing something with timeflags/stamps or whatever to just make play the video slightly faster, but with the SAME frames I already have?
    I don't understand this
    (By the way, I am doing my first steps into this blu-ray thang too. So I think that it is inevitable coming across converting film-source material to it's original 24p framerate, don't you think?)
    As for Audio, I think I know what to do to stretch/compress the sound to the right framerate. I just choose to process audio and video separately for a: understanding what I am doing and b: for hearing quality on sound. To (probably certain ) future problems with out-of-sync audio I will adress later. The first important thang for me is critically listening if the audio sounds right to me. So I prefer a good/as professional as I can get/pay audio editor to do that. Understanding frameserving teaches me what ratios I should use to stretch/compress audio (with or without tempo, pitch, pace and so on). But for now,
    Thanx manono. Highly appreciate your thinking with me. Please get back on the AviSynth thang?
    Cheers
    Ennio
  10. Since you're converting from PAL to NTSC, you're reencoding, right? So you may as well make all the changes at once. In the script. When frameserving with the script you'll be reencoding. Yes, you can go back afterwards and change the framerate in VDub (if you encoded for AVI), but what's the point?
    You're taking the 23.976fps source (resulting from using Force Film in DGIndex) and slightly speeding it up to 24fps. There are other ways to filter as well, if the video needs anything else. If you speed it up using an AviSynth script, you'll have to reencode. If you want to take the extra step afterwards and do the speed-up in VDub (which can't speedup MPEGs anyway), then be my guest. Or, you can also do the speedup at the end by applying DGPulldown with the 'Custom' box checked and set for 24->29.97 (again, assuming all this is for DVD).
  11. Member Ennio's Avatar
    May 2005
    Netherlands
    Okay, let's get into this. How much am I re-encoding? How much do I want it? Well as few as possible, I say. Try not to touch the original source-frames if you can. Instead use them untouched as they are. Mmmm.
    Here I am talking about a film-source PAL dvd. If the source is film, the original filmframes are in PAL, only at 25 framerate, right?
    If I want to go from PAL to NTSC dvd I will have to re-encode the original frames for resolution properties anyhows, yes. But with the ORIGINAL frames as my source input to go from. The speedup I will adress to by frameserving.
    Totally re-encoding from PAL to NTSC in general means to me: take the 25 frames per second, re-encode:
    A: Into another resolution (inevitable for PAL --> NTSC dvd)
    B: (I think by interpolation) In that same second, RE-ENCODING TO ANOTHER NUMBER (29.976) of TOTALLY NEW frames out of the 25 original frames. (Speed will thus be the same)
    Am I right? I think, the more re-encoding you do, the more away from home you get. Step B is not necessary i.m.o.o. (and certainly not wanted, my guess)
    So, converting film-source PAL dvd to NTSC dvd for me should only be about re-encoding (yes) the ORIGINAL frames to (the same number of) frames with just another resolution. The speed thang I wil resolve by frameserve (which is not about re-encoding, right? The source frames stay untouched)
    So yes, I still have to re-encode the resolution to a minor one. Come to think of it: as (eventhough few) re-encoding is inevitable and me taking the first steps into blu-ray: is it not wiser then to upscale my original frames to a higher resolution with a good upscaler/re-encoder and create a (24p) blu-ray? I will not suffer resolution-loss as I not go down but up in it?
    Mmmmm. Got to get into this
    If you want to take the extra step afterwards and do the speed-up in VDub (which can't speedup MPEGs anyway) .........
    ???? But with Avisynth I am fooling VirtualDub ain't I? Let it think my video is AVI?? I don't understand this.....
    Again, manono, thanx for your replies.
    Cheers
    Ennio
  12. I just have to address a few things here.
    24 fps to 23.976 fps is a slowdown, not a speedup. Also, it was done in the US to match up to the 29.97 fps of the new NTSC standard. The old standard was 30. It was slowed down from 30 to make room for color info. The PAL speedup you refer to is to match up a 24 fps movie to 25 fps PAL standard.
    Darryl
  13. Member Ennio's Avatar
    May 2005
    Netherlands
    Darryl
    I am aware of this Darryl. I read this thread over. Please where did I give you the impression that 24 --> 23.976 or 25 --> 24 should be a speedup? (Or, maybe otherwise: 23.976 --> 24 or 24 --> 25 should be a slowdown?)
    I mean if you have a number of frames in video then logically a higher framerate will play faster than a lower framerate. Curious... or, am I missing something here?
    Thanx
    Ennio
  14. I messed up earlier. Ignore all that stuff about ForceFilm in DGIndex and speeding up from 23.976 to 24fps.
    If you're converting from PAL to NTSC you at least have to resize from 720x576 to 720x480. That means a reencode.
    You have to encode at one of the acceptable framerates (23.976, 24, 25, 29.97fps). But you don't want to encode at 29.97. If you're aiming for a 24fps result, encode for 24fps (with AssumeFPS(24) added to the script) and afterwards run the MPV through DGPulldown as described earlier, with it set for 24->29.97fps, and the result will be an NTSC compliant 29.97fps M2V. That way the encoded output framecount will be the same as that of the source. The pulldown tells the player how to output duplicate fields to get it up to interlaced 29.97fps. No frames get interpolated or created when being encoded.
    If you're encoding for DVD, while you might test out your script in VDub, to make sure it's good, you'll open it directly in your MPEG-2 encoder, CCE, HCEnc, whatever. VDub has nothing to do with MPEG, unless you intend to frameserve out of VDub to the encoder, which you don't want to do.
    Nov 2009
    I think perhaps you don't exactly understand the term "frameserve"
    This statement describes frameserving in your own words, "???? But with Avisynth I am fooling VirtualDub ain't I? Let it think my video is AVI?? I don't understand this..... "
    The speedup or slowdown is a simple framerate conversion.
    You can do this by frameserving with Avisynth.
    I do a pal to ntsc film conversion by frameserving to an mpeg2 encoder with a script like this:
    AssumeFPS("NTSC_FILM", true)
    ResampleAudio(48000)
    LanczosResize(720, 480)
    The AssumeFPS slows the pal from 25fps to 23.976fps, adding "true" also slows the audio to match the video.
    So it's just a one step process for video/audio together.
    To frameserve is not just about framerate conversion.
    Jul 2009
    Spain
    What you are missing here is that Avisynth serves up uncompressed (decoded) frames, not the original compressed frames from the source video. So reencoding is always necessary, even if your script does no filtering at all.
  17. Member Ennio's Avatar
    May 2005
    Netherlands
    Aha, I think I get it. Let me check if I see thangs right, ok?
    Because I use the DGindex *.d2v file as source in my Avisynth script, Avisynth will "see" decoded video (as DGIndex "serves" it as decoded video, so to say?) Am I right with this thought? That's why it can do frameserve (by this "AssumeFPS("NTSC_FILM", true)" line), correct?
    Cheers
    Ennio
  18. Member
    Jul 2009
    Spain
    Yes, but the point is all Avisynth source filters serve decoded video to the script processor, because that's what it works with.
  19. Member Ennio's Avatar
    May 2005
    Netherlands
    OK I understand
    Thanks for explaining Gavino
    I think it's time now to spend time playing around with DGIndex and the basics of AVS.
    What I don't understand is that in the manual of DGIndex it says it can create an AVS script automatically, but the (still few) times I saved my project, there was no AVS script outputted. How can I achieve this?
    Cheers
    Ennio
  20. I just tried and couldn't make it work. You don't need it anyway as I think all it does (or all it's supposed to do) is fill in the path for the MPEG2Source line of a template .avs you've created yourself. It's not going to automatically create any sort of filter chain for you. Create your own templates for the different kinds of things you use the scripts for and fill in your own MPEG2Source line paths. I don't know of anyone that uses that feature. I'm sure it works but I couldn't figure out how to make it work, and you shouldn't need it anyway.
  21. Member Ennio's Avatar
    May 2005
    Netherlands
    I think I figured it out manono
    In the Quick Start Guide of DGIndex the thing to do is one time making a simple avs script that only has the decode.dll path and sourcepath. Mine looks like this:
    LoadPlugin("D:\Software\DGMPGDec 1.5.7\DGDecode.dll")
    MPEG2Source("myvob.d2v")
    When you load a video in DGInex, go to Options --> AVS Template and "Change Template file". Browse to the manually made script you made, and when saving project in DGIndex it automatically generates this AVS script. So you can load it directly into eg. VirtualDub. I think it comes in handy if you are using a certain script many times, so you don't have to manually type it every time. The AVS script will have the right paths to decode.dll and *.d2v, my guess.
    Now what I don't understand is this:
    I took a part from a moviesourced NTSC dvd and saved my project two times: one time with "Honor Puldownflags" and one with "Forced Film".
    Both automatically generated AVS scripts I loaded into VirtualDub and with Video --> Full processing mode I saved the AVI's.
    In GSpot both AVI files are stated with codec "DIB (_RGB)" name "BI_RGB Raw Bitmap".
    Now, in DGIndex's manual it says that served video is only converted from YUV to RGB when using "Forced Film", right?
    In both *.d2v indexes I can see the line: "YUVRGB_Scale=1".
    Must I think then that DGIndex ALWAYS will serve the (of course decoded) video with RGB output? (If so, I don't think I should mind, should I? Because RGB is uncompressed video-information opposite to YUV (which imho is compressed to digital component video) and thus better used as source)
    Or: is Avisynth doing this? Or: is Virtualdub doing this?
    EDIT: I think I have something. VirtualDub is doing this because I used "Full Processing mode"> I tried "Direct stream Copy" also and now the outputted AVI is stated with codec "YV12" name "IYUV w/ U & V switched". I understand know the difference in these settings in VirtualDub. But, it raises this question:
    According to DGIndex's manual, when using "Forced Film" the served video will be decoded to RGB oputput to, right? Why then, when I use "Direct stream copy" in VirtualDub and output the AVI, the result will be an YUV coded AVI and not a RGB??? You know what I mean?
    The difference in Field Operation is the line that makes the difference for decoding in 29.976 or 23.976 fps. It raises this question though: why is the "YUVRGB_Scale=1" line then in both d2v scripts? mmm...
    And: I demuxed both *.m2v videostreams also. Now, in Gspot it says "MPEG2" codec. codec NOT INSTALLED???
    But when I load the original VOB into GSPot, it says codec "MPEG2" and codec INSTALLED. Now what to think of that?
  22. Originally Posted by Ennio View Post
    Why would you use Full processing? Part of the advantage of using an AviSynth script is that you can use Fast Recompress, although I understand if you're doing no filtering in VDub it doesn't get converted to RGB first.
    No, it always stays as YV12, no matter the field operation. The only time RGB enters the equation is if using a VFAPI to frameserve (which you should never do). Where does it say that using Force Film forces a conversion to RGB?
    I take it you didn't compress to any codec, but left it uncompressed with the huge sizes it generates.
    It means you're using the PC Scale (as you should) rather than the TV Scale.
    If it's an XviD or DivX AVI, it's YV12. And you can't Direct Stream Copy an AviSynth script. It'll get encoded.
    If you can play it (and you can), don't worry about it.
  23. Member Ennio's Avatar
    May 2005
    Netherlands
    A way of teaching myself is playing around with settings so I will fully understand what an action leads to. In this case I am learning about what different VDub settings will result to. I just want to learn to understand every step I take in any prog. It was my idea that when I output in RGB, which is uncompressed, the next program (eg. an encoder) will have uncompressed source, which to my feeling would be better. Is it actually??
    I will have some VDub reading to do as I want to understand this “Fast Recompress” thang you’re talking about.
    I read back and I oh man I was totally wrong. I had totally different understandings messed up. Sorry. Indeed I learn now, when frameserving with VFAPI, then RGB kicks in. I understand, reading the VFAPI text file, that is is a step outside of DGIndex (which is logical to me now: DGIndex is about decoding mpeg, not frameserving as I learn) and I will need the VFAPI software separately. This is clear to me now I think, thanks, but:
    If I do want the 23.976 fps to be frameserved to 24 original film framerate (again, just for trying out now), why should I never do that with VFAPI? Does it give bad results? (I want to give it a try anyhows, just for understanding’s sake) Are there better ways? Want to learn about this too.
    I think I understand the YUVRGB line in DGIndex file now. It’s about clipping color space or leaving in full range (pc scale, which is what we want of course?) This line has NOTHING to do with YUV to RGB decompressing then, only the color dynamics of the served video (be it YUV OR RGB), right?
    Big thanks for staying in there with me, manono
    Cheers
    Ennio
    Edit: Now I come to think of it: about the VFAPI thing:
    Since VFAPI frameserve does not happen in DGIndex but separately (if I understand the VFAPI.txt correctly) why should there be this DGVfapi.vfp file in the folder where DGIndex.exe is?? Is it needed vor video preview or something?
  24. You have to understand, I went through my learning phase years ago and some things I do not because I discovered they were the better way to do things, but because better and more experienced people than I said they were better. I don't really see the need for you to reinvent the wheel just because you're learning something new. You can just follow the tried and true methods with the confidence that they are the correct way to do things. For example, when AviSynth became practical to use (meaning, for me, when the IVTCs became robust) I dropped frameserving with VFAPIs like a hot potato. Anything that forces an unnecessary colorspace change is to be avoided. Sometimes it can't be avoided (like when doing color correction), but when there are better and faster (much faster) ways to do things, use them. So, I'll avoid the VFAPI questions as being pointless and useless.
    First, there's no need to save as uncompressed. It makes for a huge filesize and it changes the source colorspace. So, to answer the question, no, it's not better. AviSynth serves up uncompressed video anyway (as Gavino tried to explain earlier). There are reasons to use lossless (not uncompressed) AVIs sometimes to send to the encoder, but they have more to do with a slow filter chain than anything else. If I have a script that runs slowly and I'm going to run 5 passes in CCE, it makes sense to create a Lagarith lossless AVI in YUY2, and then frameserve that into CCE (using an AviSynth script and AVISource) for the encode to MPEG-2. The overall timesavings can be considerable because the slow script gets run only once.
    Don't do anything with a VFAPI. If for some peculiar reason of your own you want the video to play at 24fps, just add AssumeFPS(24) to the script.
