  1. Hi,
    Ive recently began using xvid_encraw as a command line alternative to gknot for encoding my mpeg2 to avi - i have done so with quite good success, however issues arise in attempting to get it to achieve a target size.
    Though i use the -size flag int he second pass encode, it is generally not accruate as gordian know usually does. I then decided to compare the mediainfo for the video output(no audio) of the xvid_encraw and the gordian knot one - and apart from the bitrate which si different, the only difference i could see which would affect that was listed under video as "Stream size" and "Bits/(Pixel*frame)"
    On the XviD_Encraw it was:
    Bits/(Pixel*Frame)               : 0.173
    Stream size                      : 16.3 MiB (99%)
    Whilst the one done by goridan knot via vdubmod was:
    Bits/(Pixel*Frame)               : 0.188
    Stream size                      : 17.7 MiB (99%)
    I used the same AVS for both encodes.
    I anyone could provide any assistance, it would be greatly appreciated.
    Thanks.
  2. Member midders's Avatar
    Sep 2008
    Originally Posted by onesikgypo
    Though i use the -size flag int he second pass encode...
    Just a stab in the dark, but I was always told that you should use exactly the same options for the first and second passes, apart from the -pass 1/2 and the name of the output file; have you tried putting the -size flag in the first pass as well?
    Slainte
    midders
  3. Stream size, and bits per pixel per frame are simply derivatives of the bitrate:
    bits per pixel per frame = bitrate / fps / width / height
    stream size = bitrate * running time
    So obviously, different bitrates will result in difference in those measurements.
    Compare things like number of consecutive B frames, min and max quantizers, GOP size, Motion Search Precision, Adaptive Quantization, etc. Those settings can cause and xvid encoder to miss the requested bitrate.
