I've been using an earlier version of MEGUI (build 0.3.0.1017 i think) without any problems.
Today, I let the automatic update for MEGUI do it's thing (it updated something like 38 files, x264 was one of the files that was updated), and low and behold now x264 keeps crashing on it's second pass. It crashes pretty much once it starts the second pass, maybe like 3-4 seconds in.
AVS Script:
# Set DAR in encoder to 47 : 20. The following line is for automatic signalling
global MeGUI_darx = 47
global MeGUI_dary = 20
LoadPlugin("C:\Program Files\megui\tools\dgavcindex\DGAVCDecode.dll")
AVCSource("E:\Storage\Ripped movies\MeGUI\U-571.dga")
#deinterlace
crop( 0, 2, 0, 0)
LanczosResize(1280,544) # Lanczos (Sharp)
#denoise
TRIM (35000,35250)
I've set the AVS Script in this fashion MANY times without any problems.
This is a snapshot of what my previous x264 configuration looks like:
This is what the new x264 config looks like:
what does the error message say?
are you using the new patched builds?
http://forum.doom9.org/showthread.php?t=151159
some people with amd cpu's have issues with certain x264 builds that use a different compiler and optimized for core2. Replace the x264.exe with another from x264.nl or http://komisar.gin.by/ -
error message says "a problem has ocurred with x264 and windows has to close the program"
My cpu AMD Athlon 2800+
1.5G RAM
ATI Radeon HD 3650 -
i went to http://komisar.gin.by/ how do i know which one to get?
Yes.
This one should work for AMD
http://komisar.gin.by/old/1376/x264.1376kMod.generic.x86.exe
Do a test on a short clip to make sure. It might be something else in your configuration -
It worked! Thank you sooooo much! I've been trying to figure this out all day!
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 04:59 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
By NWNewell in forum Newbie / General discussionsReplies: 7Last Post: 18th May 2009, 17:10 -
x264 Encoding Crashing on all Apps!
By cbstryker in forum Video ConversionReplies: 18Last Post: 19th Jan 2009, 23:29
