Hello,
I was watching Heroes 4x13 episode, at the beginning there's a scene in slow motion 24p shot for sure at 30p or 60p.
The scene went from slow motion to real motion. If it was shot in 60p or 30p going to 24p (real time motion) would definitely show a very noticeable shutter (for the dropped frames)! So how is that possible, the scene shown at 24p was smooth as the previous slow motion (i'm not talking about different "scenes" but THE SAME scene from the same shot)
Many high end cameras have overcrank and undercrank with variable frame rates in increments/decrements of 1
In post production, you could also use programs like after effects, which can remap time and do effects like speedup and slowdown -
Well I stopped watching heroes after season 2 , but they certainly have the budget to use decent cameras and post production. You would get best results by doing it during shooting
Slowing down 60 fps to 24 different images per second while retaining the 60 fps rate doesn't drop frames, it duplicates frames. If you want to create a 24 fps output file you just slow down the frames (instead of displaying each frame for 1/60 second you display each frame for 1/24 second).
why don't they make the new 3d camcorders record at 24p they do 60p
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 11th Mar 2012, 14:56 -
24p source to 24p DVD - am I doing it right?
By Killer3737 in forum Video ConversionReplies: 30Last Post: 14th Oct 2011, 18:40 -
FFmpeg - 60p to 30i
By bunklung in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 19:57 -
24p -> pal -> ntsc back to 24p
By StrobeLightEpileptic in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 00:56 -
Deinterlace 60i -> 60p, yes, 60p, not 30p.
By 123Mike in forum Video ConversionReplies: 20Last Post: 4th May 2009, 13:43
