Page 4 of 4
FirstFirst ... 2 3 4
Results 91 to 114 of 114
    Jul 2009
    Spain
    Originally Posted by brassplyer View Post
    Script error:There is no function named "m4"
    (DeHalo_alpha.avsi, line 20)
    The m4 function is at the end of the DeHalo_alpha.avsi file:
    function m4(float x) {return(x<16?16:int(round(x/4.0)*4))}
  2. Originally Posted by brassplyer View Post
    It's in the plugins folder per the screen cap above
    Like mvtools, there's several versions of masktools as well. I could only see the mt-masktools in your screenshot, not MaskTools.dll.
    I think dehalo relies on the older version, (i.e. MaskTools.dll). It is hotlinked in the mediawiki
  3. Brassplayer, someone in another thread linked to this site:
    http://in-trans.appspot.com/entry/fictionjunction-yuuka-popjam-2005
    The links to the exact filter versions there might help you.
  4. Member brassplyer's Avatar
    Apr 2008
    Can you take a screen shot of your plugins folder? Still getting the same error.
  5. Originally Posted by brassplyer View Post
    I don't think it will help you, my plugins folders is a mess . It would probably confuse you more than anything - I have about 500 items, folders, avsi, avs, documents etc... that doesn't include subfolders and their contents. I should delete everything and start over
    Try downloading the dehalo avsi again and replace it . That line defines function m4 within that script, so maybe yours is corrupted or missing stuff.
  6. Member brassplyer's Avatar
    Apr 2008
    Okay, I'm revisiting this, never got it to work before and want to get to the bottom of why.
    Given Jagabo's original scripts
    AVISource("test.avi")
    ConvertToYV12(interlaced=true)
    TempGaussMC_Beta1(sharp=0)
    Dehalo_Alpha(darkstr=0.9,brightstr=0.9)
    MCTemporalDenoise(settings="high")
    If instead I do just this much
    It works.
    However, when I add the dehalo filter
    I get the error "Script error: there is no function named "expand"
    (, line 21)
    This is the dehalo filter I'm using.
    http://avisynth.org/mediawiki/upload/8/8b/DeHalo_alpha.avsi
    Alternately, if I do Tempgauss and the MCTemporaldenoise
    I get
    FFT3DFilter: Cannot load FFTW3.DLL!
    (, line 242)
    Any ideas as to what's causing these errors?
    Jul 2009
    Spain
    DeHalo_alpha requires the older version of MaskTools: http://manao4.free.fr/MaskTools-v1.5.8.zip
    You need to put fftw3.dll in the appropriate system folder.
    For XP, this would be C:\WINDOWS\SYSTEM32.
  8. Member brassplyer's Avatar
    Apr 2008
    Thanks. Is there a problem with different versions of MaskTools in the plugins folder - does it need to be one or the other?
    What is and where do I find FFTW3.dll?
    I find this
    http://fftw.org/install/windows.html
    but extracting the files nets several .dll's none of which are specifically called fftw3.dll
    Jul 2009
    Spain
    Both versions can co-exist as they intentionally use different function names (eg expand vs mt_expand).
    I find this http://fftw.org/install/windows.html
    As noted in the FFT3DFilter documentation, you need the (older) version from ftp://ftp.fftw.org/pub/fftw/fftw3win32mingw.zip. (It's actually on the page you quoted, but under 'older stuff'.)
  10. Member brassplyer's Avatar
    Apr 2008
    They both have the same name, how do I get them both into the plugins folder?
    Jul 2009
    Spain
    What do you mean?
    For v1.5.8, the file is called MaskTools.dll.
    For v2.0a, it is mt_masktools-25.dll.
  12. Member brassplyer's Avatar
    Apr 2008
    What do you mean?
    The one I had in there was even older, it was also MaskTools.dll, I replaced it with v1.5.8
  13. Member brassplyer's Avatar
    Apr 2008
    Okay, making progress, it now works with Dehalo_Alpha, but when I add the temporal denoise
    I get this
    Image Attached Images
    Jul 2009
    Spain
    You need the latest version of RemoveGrain.
    You're not having much luck with this so far - I hope it's worth it in the end.
  15. Member brassplyer's Avatar
    Apr 2008
    I'm making progress, couldn't get it to do anything originally. Avisynth seems to be something of a butt-pain to get to work but seems like it could be useful. Seems it's better to know about it than not know about it.
  16. AviSynth is the most powerful tool for video processing. The problem is there is not much coordination between the developers around the world. So you end up with this version number mess. But once you get it set up and learn to use it you'll find it indispensable. This particular use, TempGaussMC_beta1mod(), is a rather difficult one to get set up for beginners.
    Oh, and TempGaussMC_beta1mod() is the latest version. I recently set my system up to use it and the older TempGaussMC_beta1() no longer works. So you might try using the mod version:
    http://avisynth.org/mediawiki/TempGaussMC
  17. Member brassplyer's Avatar
    Apr 2008
    Someone referred me to a beta2, which I'm told is the newest. It seems to be marginally faster, seat of the pants assessment is it yields about the same results.
    Btw, I really appreciate all your input on this issue since I first posted about it several months ago.
  18. Member brassplyer's Avatar
    Apr 2008
    Is it correct that when deshaking the 60p Huffyuv files I should have it set on square pixels?
  19. Set the pixel AR to whatever the pixel AR of your source is.
  20. Member brassplyer's Avatar
    Apr 2008
    If the Huffyuv file is made from a DV file, what would that be?
  21. If regular DV, 4:3 if fullscreen, 16:9 if widescreen
  22. Member brassplyer's Avatar
    Apr 2008
    I don't think we're talking about the same thing, I'm talking about these options - assuming the Huffyuv file that's being deshaken was made from a 16:9 (anamorphic I believe) file.
  23. Member
    Jul 2009
    Spain
    You want Anamorphic NTSC or Anamorphic PAL, depending on your source - probably NTSC, if you're in the USA.
  24. The very first post of this thread had a 16:9 NTSC NTSC DV AVI. If you're still working with that file or one like it you want the Anamorphic NTSC (1.215) setting.
