VCD Cutter is a very easy to use free VCD Cutter which can cut clips from any of your VCD in simple 3 steps. It maintains the VCD quality so you can enjoy the final clipped video without any quality loss.
---> http://www.vcd-cutter.com/
VCD Cutter Screenshot
To cut clips from your VCD you need to follow simple steps -
# Open the VCD(DAT) file by clicking open.
# Mark start and end of VCD Clip to be made.
# Click Save and choose the output filename.
# Done.
So if you want to cut clips from your VCD, simply download VCD Cutter and enjoy.
License: Freeware
Platform: Windows All
---> contact us : support@vcd-cutter.com
PS: I have tested this program. But, it crashes on my system. Does it work for you?
Thanks.
Best Regards.
devil (johner)
Results 1 to 1 of 1
Looking for AVI cutter
By rocks911 in forum EditingReplies: 2Last Post: 27th Jan 2012, 16:23 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 15:06 -
a video cutter
By Benygh in forum EditingReplies: 5Last Post: 3rd Nov 2009, 15:55 -
DVD Cutter
By akakiami in forum EditingReplies: 6Last Post: 23rd Oct 2008, 07:04
